Brake Rotors
Old 04-09-2014, 09:20 AM
mxjones's Avatar
Default Brake Rotors
Hello, I own a 2009 A6 w/18" wheels--I need to replace the rear brake pads and rotors. I'm looking for recommendations on the rotors--I don't want to go with oem rotors. I am going to put a set of akebono pads on. Thanks for the help.
Old 04-09-2014, 09:35 AM
raj99's Avatar
Try using the <b>SEARCH</b> function...it's quite handy
Here let me help you: https://www.audiworld.com/forums/sho....php?t=2864075
or this: https://forums.audiworld.com/search....archid=6846359
I use Brembo rotors with Akebono ceramic pads on my C6 4.2
Old 04-09-2014, 04:39 PM
mxjones's Avatar
Having a hard time finding Brembo's, I'm leaning towards Zimmerman's--any experience with these?
Old 04-09-2014, 04:48 PM
MainlandMig's Avatar
i just did my fronts and soon my rears
i went with stoptech slotted and HAWK HPS pads
i have no regrets .. am very satisfied
Old 04-09-2014, 07:12 PM
raj99's Avatar
Mig, you can't go wrong with Stoptech rotors. Although I haven't used HPS, I've heard good things about them. How's the dust with the slots?
Old 04-09-2014, 07:29 PM
No Bozos!
squidix9's Avatar
Focus on the front more so than the rears. Changes up front will make more difference than the rear. I use stock rotors and Pagid in the rear. Zimmerman with Minted Red in the front. They stop great but cleaning is a bear, and when you stop, you stop, not gently. Stoptech with HPS should be excellent.
Old 04-10-2014, 04:56 AM
Senior Member
Catamount90's Avatar
I just replaced the rotors and pads on my '05 A6. I am now a huge fan of the Zimmermann coated rotors. These don't rust, so the entire assembly just looks really clean behind your wheel.
On the advice of others, I paired them with Wearever Gold ceramics from Autozone. Yep, Autozone. After bedding in this setup I've been really impressed. $270 for the whole deal.
I bought the rotors from Amazon.
Amazon Amazon
Zimmermann coated front rotors, 321mm, Amazon $123.86
Zimmermann coated rear rotors, 302mm, Amazon $81.83
Wearever Gold ceramic pads, front, GNAD 1359 $34.40
Wearever Gold ceramic pads, front, GNAD 1108 $28.67
Old 04-10-2014, 07:00 AM
my past 2005 a6 and current 2011 had oem rotors and pads
2005 seemed really bad w dust
2011 seemed a bit better but still bad
after reading a bunch i decided this was best setup for me
i could have gone ceramic pads but these HPS were a better performance balance for me
i heard they last a long time but were hard and ate up some softer rotors but stop techs are damm hard and a great match
ran this set up on my 2005 and i was impressed on performance and reduction in dust
i was really impressed on how long they lasted
drilled rotors look cool but i dont need that much heat dissipation and wanted the extra rotor real estate for pads to grab on
again great replacement upgrade to oem
Old 04-10-2014, 12:56 PM
enoch861's Avatar
By the way, if you decide on Brembo rotors, I have the Brembo 25661 rear rotors if you're interested. I have no use for them since they won't fit my car and no one locally wants them. They're brand new and never been put on. If you're interested, PM me and we can talk!
Old 04-10-2014, 02:32 PM
The_Mizarc's Avatar
I'm very happy with my Adam's Rotors and Akebono Ceramic pads. The option of choosing the rotor design was a big plus for me.
Quick Reply: Brake Rotors
