FM signal gone really bad
FM signal has gone really really unbearable. Used to be perfect. I replaced the amplifier booster on the back window and it has made no difference. Any ideas where to go from here?
Should have added its a 2005 prefacelift. Not sure if the shark fin antenna is oem or if its even meant to be there. Car has GPS and dab radio if it helps
No Bozos!
Connectors
I had an A8 in the other day that I tried everything on. I replaced the amp which should have been bad with no effect. It turns out the cable from the amp running to the front was bad. Try wiggling the cable along it's length and see if it suddenly gets better.
Holy smokes a fuse, never checked them. any idea what one? Rear defroster is working. Need to find a fuse layout.
Just checked. No fuse in aerial amplifier! Hopefully this is the problem(I assume it is). I'll report back tomorrow
It was one of the fuses in the passenger side fusebox (side of dash). The panel had a diagram and it's in the owner's manual.
It is most likely the coax cable going to the shark fin antenna. My B5 Passat had the same problem. Bad thing is that the cable is not one continuous cable from the antenna, but there are two connections. One next to the radio and one next to the antenna. It is the connections that get corroded. On Audi it's amplified antenna and so the power cable may be suspect also.
In my Passat case the problem was with the connection under the headliner below the antenna. The plastic seal between the antenna and the roof sheet metal got hard and cracked. After while if it rained water got to the cable connections and corroded the connection which made for bad reception.
