changing out output shaft seal... what gear oil?
Old 04-13-2014, 01:57 PM
omarcarbomb's Avatar
Default Going to replace with new flange and seal
Silver:
From your prior posts I'm certain about the flange, seal, and gear oil part numbers:
ZF flange 01V 409 809 A
OEM seal ( 018 409 399 A )
1L 75w-90 GL-4 gear oil
Having trouble with part numbers for:
◾(6) Output flange to drive shaft bolts (or you can reuse if you'd like, I replaced mine)
◾(4) 8 x 40 mm high grade bolts
◾(4) 8 mm high grade nuts
◾(8) 8 mm washers
not sure if this is right 6 bolts flange 01F409359 ?
coming up with nothing on the exhaust bolts?
thanks,
Old 04-13-2014, 03:00 PM
silverd2's Avatar
Originally Posted by omarcarbomb
Silver:
◾(8) 8 mm washers
thanks,
01F409359 is the single center bolt that holds the flange to the diff.
01V 409 809 A is the new type flange with the groove...the only kind they sell now, unless they have old stock without the "A". It was made for the new type seal( 01V 409 399A ) with the extra lip to form the dust labyrinth. 018 is the old type seal, but will work..it's identical, except lacks the added dust lip.
See if these ETKA pages help with other parts >>>
gk1
07-03-2003 11:00 AM
SSLEDGE1234
02-21-2003 05:05 PM
quattrotek
01-17-2003 03:05 PM
o2bnme
TT (Mk1) Discussion
02-20-2001 05:07 AM
Danny Nakhoff
06-18-1999 07:20 AM
Quick Reply: changing out output shaft seal... what gear oil?
