Coolant temperature sensor location?
Nos. 11 and 15 on the diagram
11 - Coolant temperature sender -G62
15 - Radiator outlet coolant temperature sender -G83-
Thank You very much, it's g62 and seems to be quite difficult place to change. I let you know, how I replaced it.
Generally, the radiator outlet sensor just turns on after run fans. The coolant temp sensor is the one controlling gauges, ECM.
The o rings stick to the sensor and the body. Put a wrench on the plastic wire housing and twist, that breaks the o ring free. Some have had better luck with the engine slightly warm, not cold or hot. Always use new o ring. And put silicone grease on the o ring.
I changed temperature sensor but it didn't resolve my problem. Problem is that radiator fan starts blow full blast allways when I start car even the engine is cool. Fan stops after I stop the engine. Only when the Webasto is on, radiotator fan don't blow. Webasto has installed just before when I noticed fan problem. Can webasto cause this kind of problem or is it the fan control module broken on something else?
Still stuck......
kind regards
Paul.
