Attention C6 Owners experiencing oil leaks from timing chain cover gasket!
Old 02-22-2013, 09:39 AM
Tee-Dub's Avatar
My 2006 Avant has this problem. Blows oil out during hard acceleration. I was just told that it was coming from the timing covers...
Old 02-25-2013, 09:59 AM
balla4lyfe4421's Avatar
Mine had the same problem took to a indie and seemed to fix the problem by tightening everything and changing a valvle in the crankcase ventilation system. tightening valve covers, and timing chain covers.. oh and put a new oil filter housing seal..+ a oil change. all said and done $800
Old 02-25-2013, 12:16 PM
Tee-Dub's Avatar
Were they able to tighten the timing covers without pulling the engine? If not - what a job that would be!
I read somewhere that a blocked PCV valve could cause the oil leak but it seemed to more affect the 3.0.
Old 02-27-2013, 09:20 AM
They did it all without dropping the engine. Thank God. Not a good feeling when they have to do that.
Old 02-27-2013, 09:31 AM
raj99's Avatar
AlteredEgo79, I sent a PM to you regarding the AoA case and was wondering how I could possibly have mine checked under the same potential issue...please PM me...thanks
Old 02-27-2013, 10:07 AM
04_ultrasport's Avatar
It is not necessary to drop the engine to reseal the timing chain covers, it can be done in the car. I've resealed chain covers on 3.2L a lot and it is a common problem. The covers use sealant not a gasket and over time they start to leak just like any other cover on the cars. Its really not all that different than getting a leak from the cylinder head covers. Over time and depending on the climate around you will determine how long it takes for them to start leaking.
Old 02-27-2013, 10:18 AM
raj99's Avatar
I recently installed new valve cover gaskets on both sides, but would also like to reseal the timing chain covers...is there a writeup on this?
Old 06-12-2013, 02:57 PM
  #18
Jay Valen's Avatar
Default Oil Leaks Recently Found in Service Check
I recently had 2 oil leaks found when I had to turn my Audi A6 3.2 in early because the oil light came on 3000 miles before the next due oil change. The leaks found were Valve Cover Gasket and the Rear Timing Chain Cover. After seeing this forum I am wondering if I also have a case to have this issue fixed as a recall by Audi.
Any help or advice is welcomed.
Old 06-12-2013, 03:00 PM
  #19
Jay Valen's Avatar
Let me know if you have received any new information on getting this issued fixed as a recall from Audi..? I have 2 leaks in the valve cover area and rear timing chain gasket cover at the moment. Thanks
Old 06-14-2013, 05:24 AM
  #20
R3Wood's Avatar
I had to do mine at 48,000 miles.
Quick Reply: Attention C6 Owners experiencing oil leaks from timing chain cover gasket!
