Coolant temperature sensor location?
Old 02-15-2014, 11:02 AM
Virkailija's Avatar
Default Coolant temperature sensor location?
Could somebody help me, I can't find coolant temperature sensor? Car is A6 2009, 2.0 tdi cr.
Old 02-15-2014, 04:54 PM
put3namo's Avatar
Seem like there are couple of temp senders
Nos. 11 and 15 on the diagram
11 - Coolant temperature sender -G62
15 - Radiator outlet coolant temperature sender -G83-
Old 02-15-2014, 08:21 PM
Virkailija's Avatar
Thank You very much, it's g62 and seems to be quite difficult place to change. I let you know, how I replaced it.
Old 02-16-2014, 07:58 AM
Worldwidebeagle's Avatar
Generally, the radiator outlet sensor just turns on after run fans. The coolant temp sensor is the one controlling gauges, ECM.
The o rings stick to the sensor and the body. Put a wrench on the plastic wire housing and twist, that breaks the o ring free. Some have had better luck with the engine slightly warm, not cold or hot. Always use new o ring. And put silicone grease on the o ring.
Old 04-12-2014, 09:41 PM
Virkailija's Avatar
I changed temperature sensor but it didn't resolve my problem. Problem is that radiator fan starts blow full blast allways when I start car even the engine is cool. Fan stops after I stop the engine. Only when the Webasto is on, radiotator fan don't blow. Webasto has installed just before when I noticed fan problem. Can webasto cause this kind of problem or is it the fan control module broken on something else?
Old 03-22-2019, 04:32 AM
Tautvydas Stanynas's Avatar
did you slove it? I got same problem
Old 08-06-2019, 07:42 PM
Anthony Ivory's Avatar
Default 2011 Q5 coolant temp sensor
can someone please help me locate and remove the engine coolant temperature sensor. I can’t find any information anywhere on this
Old 08-07-2019, 01:35 AM
hrc4u's Avatar
Try post over @ the Q5 forum... This is the A6/S6 forum
/H
Old 03-25-2020, 01:22 PM
Paul3smith24's Avatar
Default Still stuck......
hi everyone, newbie here..... I have a 2009 A6 2.0 tdi alone black edition and I need to replace G83 cooling sensor. I understand the above image on the location of the sensor but still can’t find it 🤯🤯. Does anyone have a video showing where it is or some images of the area ?
kind regards
Paul.
Old 03-25-2020, 01:54 PM
AudiNike12's Avatar
Check on the coolant pipe that goes from the top of the EGR valve. Should be there
Quick Reply: Coolant temperature sensor location?
