VAG-COM Discussion
Does this mean my ECU is bad?
Old 04-10-2014, 12:47 PM
kylepet's Avatar
Default Does this mean my ECU is bad?
Driving down the highway and the EPM light and MIL come on with reduced power but still running reasonably well. Pull over check it out with no obvious issues. Starts back up and EPM and MIL come back on with reduced power but still drivable. 5 miles down the road it gets worse and worse. I'm close to home so pull off and take side streets home. It deteriorated to the point it would barely come off idle. Pulled over to let things cool off thinking it was a sensor. 15 minutes later it runs much better but EPM and MIL still on.
Get home and it has the following codes, none of which it has had prior:
11 Faults Found:
19756 - Exhaust Camshaft Position Sensor Bank 1 (G300)
P3300 - 002 - Short to Ground - MIL ON
17800 - Camshaft Position Sensor Bank 2 (G163)
P1392 - 001 - Open Short to Plus - MIL ON
17746 - Camshaft Position Sensor (G40)
P1338 - 001 - Open or Short to Plus - MIL ON
19759 - Exhaust Camshaft Position Sensor Bank 2 (G301)
P3303 - 001 - Open or Short to Plus - MIL ON
18041 - Accelerator Position Sensor 2 (G185)
P1633 - 002 - Signal too Low - MIL ON
18047 - Accelerator Position Sensor 1/2 (G79/G185)
P1639 - 008 - Implausible Signal - Intermittent
18321 - Pressure Sensor for Brake Boost (G294)
P1913 - 002 - Short to Ground - Intermittent
17796 - Control Module Malfunction - DBW Throttle Monitoring
P1388 - 008 - - Intermittent
17536 - Fuel Trim; Bank 1 (Mult)
P1128 - 001 - System too Lean - Intermittent
17538 - Fuel Trim; Bank 2 (Mult)
P1130 - 001 - System too Lean - Intermittent
16485 - Mass Air Flow Sensor (G70)
P0101 - 008 - Implausible Signal - MIL ON
I monitored all the throttle position sensors on measuring blocks and they seem okay. I cleared the codes and started it back up. Idles unstable but has only the following codes:
I think the ECU went bad but would appreciate feedback from anyone with experience. Thanks!
Old 04-10-2014, 12:49 PM
kylepet's Avatar
Edit: Not EPM, EPC.
kylepet
04-18-2014 09:13 AM
allroad(s) lead 2Gavin
Audi allroad
12
08-12-2012 05:58 AM
mydreamcar
12
01-06-2009 03:54 AM
alpinab7
Audi Original "S" Cars
11-07-2006 12:30 PM
DYOS4
12-27-2005 10:58 AM
Quick Reply: Does this mean my ECU is bad?
