TDI performance
#51
This is a good explanation, however .....
Let's look at the simplest equation:
Power = torque * rotational speed * 2PI (ignoring units) or
Power = Torque * RPM
pretty simple!
So obviously power is a function of torque. It is the function of the transmission to "do the right thing" and keep things at the high torque portion of the engine to get the right power to the wheels. If you look at the torque and power bands of the TFSI and the TDI engines things should be pretty obvious how all this depends on RPM of course and how these 2 engines differ and how the 0-60 accelerations are virtually identical even though the TDI has higher torque (428 lb-ft) and lower power (240hp) and the TFSI has higher power (310hp) and lower torque (325lb-ft).
(I do not read physics forums but I did pass 8.01)
pretty simple!
#52
agreed
Agreed. I was trying to further the discussion in the same direction, perhaps making a stronger point. Sorry for the confusion.
#53
pretty simple!
pretty simple!
I'm not trying to downplay the TDI. I bought the S6 in early 2013 before the TDI was available in the US. If it were available, then I would have strongly considered it and saved a few bucks. I'm sure the cars feel pretty much the same under moderate acceleration (2,000-4,000 RPM) because the torque and HP numbers are similar at low to mid engine speeds.
#54
This is where you are wrong. For all out acceleration, the transmission's job is to keep the engine at max power, not torque. The "right power to the wheels" is peak HP. I have an S6 which has a pretty broad torque band. It has 400+ foot-pounds between 2,000 and 5,000 rpm. For max acceleration the transmission will keep the RPMs up high near peak HP, even though torque begins to fall after 5,000 rpm. You will not get the same acceleration if you manually shift between 2,000 and 5,000 rpm, even though you are at peak torque. You will notice the same thing in your car.
#55
Not quite. Power is needed to fight resistance. Torque is needed reach maximum rpm in a vacuum. Go ask a dentist how fast his drill can spin. 35k rpm will probably be the answer. The drill doesn't need hp to reach that speed. It needs hp to eliminate getting bogged down while drilling your tooth. The torque in the drill will take it up to 35k and the more toque, the faster it will reach that peak. Without horsepower, the drill would grind to a halt from 35k rpm the moment it touches your tooth.
The transmission will be shifting gears at the point that it's programmed to shift. This mapping can be done to compensate for load/resistance or it can be done for efficiency (torque and low rpms).
#56
#57
thinking about anticipating acceleration not accelrating
When I was referring to the transmission doing the right thing I was thinking of keeping the RPMs at high torque in anticipation of acceleration - not while accelerating. In other words assume you are cruising along and suddenly you want to accelerate to overtake. You want the transmission to keep the gears so as to keep things at the high/maximum torque area not at the high/maximum power area (near the top of the allowable RPM range). (that is the nice thing about a car with a high torque engine). Not sure if I made this clear or if this makes sense to you.
#58
I am not sold with Diesel engines, I like the performance of the gas engine, in Europe gas is so expensive that the Diesel engines makes more sense, but in the United States/Mexico where I live the gas prices are not that expensive, I do not like the sound of the Diesel engine and the lack of performance, even if the torque is higher, that will make more sense in a Q7 if I would be hauling something, not the case in an A6/A7
I tested Q7 models side by side and I preferred the gas over diesel.
The 3.0 tfsi is really good engine, the consumption is very good, and if I wanted better economy. I would have purchased a hybrid or an electric.
Nobody buys a sports car like a Ferrari based on economy, I know these are not Ferraris but I like my cars to perform, and if I need to pay a little more I do not care.
I read this test today and it is pretty impressive what Diesel engines are doing nowadays, but for saving $72.57 for a 1184 mile trip, getting there 43 minutes later and sacrificing acceleration (6.5 vs 8.1 0-62mph) and top speed (155 mph vs 142 mph advertised) and losing 36 hp for gaining 22 ftlbs, is in my book not worth it.
http://www.roadandtrack.com/car-revi...treaks-roa0214
#59
To each his own, it's a matter of preference. I love the performance of the TDI in my new A6. I really liked the 3.0 TFSI too--great engine. To me there was no meaningful difference, but that's me, not you. I also drove a 2006 VW Jetta TDI for 7 years so my preferences are obviously different than yours. I have averaged 36 mpg over the first 1500 miles and that's going to improve. In fact, the first tank was 32 mpg, the second was 36 mpg and the third was 38 mpg. Performance wise, I am totally satisfied because at normal driving speeds when I step down to pass the car responds as fast as I personally need. I owned a MB AMG before the Jetta that was quicker, but maybe I've lost a step. Lets not get into a gas-diesel polemic. If you drive a lot on the highway a diesel can pay for itself easily, if you do a lot of city driving a hybrid or electric car is better and a 3.0 TFSI is not going to be that much less efficient than a diesel. If you want ultimate performance, don't buy an A4, A6, or Q5 or Q7 Audi. There are many other faster cars if speed is what you crave.
bebopdeluxe
A6 (C7 Platform) Discussion
09-05-2015 04:11 PM
giuseppepat
09-02-2015 02:47 AM
