Any way to add the gear indicator next to the D or S on MFD?
Old 08-30-2013, 03:57 AM
Mike O.'s Avatar
Default Any way to add the gear indicator next to the D or S on MFD?
In my Touareg, the Multi Function Display shows either D or S along with the gear the vehicle is in. Is there any way to enable this via VAG-COM?
Old 08-30-2013, 08:14 AM
AudiWorld Expert
iconoclast's Avatar
you may enable through vagcom but it will never display... i tried several different methods of coding it and just wont take.
Old 08-30-2013, 10:05 AM
snagitseven's Avatar
Not sure on the Q7, but this worked on my A6 (be sure you have the latest version of the VCDS software):
Enable Gear Display (D1-D6) in DIS
a. [02 – Auto Trans]
b. [Adaptation – 10]
c. Select “Single Gear Display” from top channel drop down menu
d. Select “D on/S on” from New value drop down menu
e. Select “Do It!”
From another member: Note: May have to select “Do It!” a few times to save the change (I only had to "Do It" once for it to work).
Old 08-31-2013, 01:40 AM
scottr13's Avatar
I'm sure mine has this as a standard option, will double check today
Old 08-31-2013, 09:43 AM
xboltss's Avatar
e. Select “Do It!”
when i go to "b", [Adaptation 10] is grey out (disable).
how can i enable that button?
thanks
Old 08-31-2013, 01:08 PM
AudiWorld Expert
iconoclast's Avatar
enter security access code.
Old 08-31-2013, 02:49 PM
xboltss's Avatar
thanks for reply
i still waiting for Service Manual is coming in 2 weeks.
Old 09-03-2013, 12:51 PM
scottr13's Avatar
Is this what you mean? D and the 6 at the side?
Old 09-03-2013, 02:40 PM
AudiWorld Expert
iconoclast's Avatar
Which year is that and which region? Judging by the color of the numbers it isn't a face lift model. I have not been able to make it work on 2010+ Q7. (Specifically 2012)
Old 09-03-2013, 03:31 PM
chickdr's Avatar
Yep- our 07 also shows the gears. The 13 Q5 loaner we had did not. Not sure why they would change that.
Quick Reply: Any way to add the gear indicator next to the D or S on MFD?
