Tire Thickness - question for those familiar with tires
Was about to go out of town with my allroad.
Then, I saw a thin piece of metal penetrate my allroad rear tire by around 1/4 - 3/8 of an inch. It went in the thicker level of the tire thread.
I was not sure if it penetrated the tire to the core, so I left the allroad at home and brought my S5 for the out-of-town trip.
My question is - how thick are the tires? Should I be worried that a thin sharp piece of metal penetrated my tires by about 1/4 - 5/8 of an inch?
That sounds like some serious penetration...but you'll know soon enough whether it caused damage (leak).
I've had a nail go into the tread block and not cause any problems when removed.
Thanks, I'll be home in a few days and see if it has lost some air. If not, 1/4 inch slice into the tire still looks pretty deep. Is there a rubber glue for that?
Ok, so I left the allroad in my garage for about 8 days, and took the tire pressure again. The 1/4 - 3/8 puncture did not cause any puncture and the air pressure remains the same.
I went to Discount Tires and asked them for an opinion. And they said, well - as long as it did not puncture your tires, it's ok. Tires are made to take some tear and shallow punctures.
I'll still probably put some rubber cement on it.
royals1982
11-15-2009 11:18 AM
