2001 AUDI A6 2.8L (FWD) TROUBLE CODES
Old 09-16-2011, 08:33 PM
JT2385's Avatar
Default 2001 AUDI A6 2.8L (FWD) TROUBLE CODES
Hi, I need some help. I have a few trouble codes and I would like some expert advice on what might the problem be.
1) 18057.P1649
2) 16502.P0118
3) 16514.P0130
4) 16825.P0441
Old 09-17-2011, 03:36 AM
Tech Guru
4Driver4's Avatar
If really want help, at least take five minutes to look up the codes.
Old 09-17-2011, 05:27 AM
rohit13's Avatar
1) 18057.P1649
2) 16502.P0118
3) 16514.P0130
4) 16825.P0441
Po441 is incorrect purge flow which has something to do with the N80 valve or the canister.
Old 09-17-2011, 07:19 AM
5v/cyl's Avatar
+1 Google is your friend.
Old 09-17-2011, 07:25 AM
radhaz's Avatar
http://wiki.ross-tech.com/wiki/index...ry:Fault_Codes
Old 09-19-2011, 09:13 PM
JT2385's Avatar
I did look up the codes, but I get various results. Which is why I asked for help from an "Expert". Thank you for your smart remark.
Old 09-20-2011, 03:02 AM
Tech Guru
4Driver4's Avatar
Or http://www.bentleypublishers.com/tec....dtc.table.htm
Bank one is right side. Always.
Old 09-20-2011, 05:27 AM
Huskerbob's Avatar
Default Codes
You might try searching for codes by entering only the part from "P" on. So P1649 yields an ABS code, P0118 is a coolant temp sensor, P0130 is an O2 sensor and P0441 is an evap system purge flow. If you add Audi to the front of the search string you also get pretty good results especially if you drill down to an Audi link. So audi p1649 yields ABS problem and an Audi solution.
czellars
02-27-2014 05:08 PM
oakland8124
2.7T V6 Discussion
02-22-2014 01:53 PM
Ryanl2488
09-04-2012 04:07 PM
wilko1
12-05-2011 08:42 AM
oillady
03-08-2009 04:06 PM
Quick Reply: 2001 AUDI A6 2.8L (FWD) TROUBLE CODES
