A/T low voltage input
Old 04-13-2014, 05:41 PM
jswillard's Avatar
Default A/T low voltage input
hello I need help I have an a6 Quattro 2.7 2003 158000 mi had the timing belt, tensioners, water pump, alternator changed on my little demon after I drove it and it died due to bad alt. car started and drove fine after repairs. had oil leak inpan due to a crack, all I di was disconnect batter and change the pn to a new on reconnected the battery cars starts fine....but no heater, defroster, heated seats, and it wont release the shifter everything else seems to work. as I said it did just before changing the pan now it doesn't do any of the above. put an obd and got code P0501(I believe) low voltage input on A/T no other codes no engine light, cleared codes still same problem but no code. Don't know if heater and others worked was a warm day no need for a heater started and shifted fine in reg, sport, and tiptronic drives. Hve disconnected battery for several hours for that reset attempt...nope. positive noet did fix oil leak.
Old 04-14-2014, 05:47 AM
SloopJohnB@mac.com's Avatar
Chances are you moved/broke an old electrical connection or wire when replacing the oil pan gasket/seal.
Drop the belly pan and look around the oil pan and check ANY wire within a few inches of the engine/pan.
Do you mean Automatic Transmission low voltage input or is AT a misspelling….enquiring minds want to know?….
I have no idea what an Automatic Transmission low voltage input is…especially if the transmission is working fine...
Old 04-14-2014, 04:28 PM
jswillard's Avatar
yes it is automatic transmission. that code no longer appears, transmission is not working to what I can tell because shifter will not be released by brake pedal, heater quit working and so did seat warmers. only wires in any proximity are the oil sensor wires.
Old 04-14-2014, 04:36 PM
OK…check all the fuses.
Old 04-15-2014, 05:17 AM
jswillard's Avatar
yes have tried that also have pulled tcm to see if has retained water in the box, no water tcm is clean. was told to check the control box under driver knee plate but cant find it there only relay boxes.
Old 04-15-2014, 06:08 AM
jswillard's Avatar
went back checked the fuses found the KI control supply fuses blows out now, this explains heated seats and inst cluster not working(heater buttond, defroster, ect) but does this actually affect the tiptronic shift lock? so there is a short somewhere that I have caused in replacing oil pan or mechanic has caused replacing alt, timing belt, and water pump, where oh where to begin looking? would take back to mechanic but wont shift out of park all the sudden after disconnecting battery to replace pan.
Old 04-15-2014, 08:58 AM
Airbag's Avatar
i would say your electrical failures due to the short and not being able to disable the shift interlock are not a coinidence.. you may need a meter and a schematic for this one..
Old 04-15-2014, 11:47 AM
jswillard's Avatar
I was told by audi dealer to disconnect the aircon sensor they have had previous problems with this and also on an another discussion site from uk this was also said to be disconnected and fix the problem with a new one, where is this sensor?
Old 04-15-2014, 05:24 PM
jswillard's Avatar
that wasn't it %@%$%@%%$%%#%@%%%$#^#$^#% all I did was disconnect the battery to change an oil pan
buratino1117
11-01-2016 12:54 PM
runoverb4
11
06-12-2007 02:24 PM
fleishelja
03-15-2005 11:05 AM
bone sTTock
VAG-COM Discussion
04-06-2004 02:26 PM
A Foore
09-30-2003 01:24 PM
Quick Reply: A/T low voltage input
