Need some control arm help
Old 04-12-2014, 10:38 AM
jseklund's Avatar
Default Need some control arm help
I am currently in the middle of replacing the control arms on my car. I have everything off and have a couple of issues.
On the passenger's side, one of the control arms was not coming out - it got half way and stopped. I finally realized the bushing was coming out with it, and this was causing it to jam up, and finally got it out.
On the driver's side, I went to put it all back together and realized the same bushing was missing! I looked at the old control arm and it came off with the control arm.
Just to be clear, I am talking about the metal collars that the lower control arms go into in the knuckles. On both rear lower control arms, the bushing seized to the control arm and came out with the arm. On the passenger side I noticed when it was halfway out and corrected it - on the driver's side it just came out (easily) with the control arm.
Does anyone know where I can buy a replacement bushing for this or what it is even called? I'd like to replace them both. Are they supposed to just press in?
Thanks.
Old 04-12-2014, 10:52 AM
SloopJohnB@mac.com's Avatar
Thanks.
These are the parts on the front and rear suspension….which one are you talking about?
If it doesn't show on the pic it's part of a larger assembly…is this the bushing into the aluminum carrier on the front? I think it's pressed into the carrier and not a replacement part…did you lose one? 26 is the rear lower control arm assembly for the front suspension.
Old 04-12-2014, 11:12 AM
jseklund's Avatar
Thanks Sloop- I'm not sure I see them in those diagrams, but you have the right part - the bushing is pressed into the aluminum carrier.
Ironically, one of the control arm tech articles has a parts diagram which shows the bushings as parts #54 and #55
https://www.audiworld.com/tech/wheel43.shtml
The diagram is at the top of the article, but I can't find this diagram anywhere else - of course
Old 04-12-2014, 01:01 PM
looks like it came from jimellisaudiparts.com
http://www.jimellisaudiparts.com/sho...rimLevel=19005
Old 04-12-2014, 03:09 PM
jseklund's Avatar
Hey, Thanks Sloop!
Unfortunately, their parts list goes to part #52 and I am looking for 54 and 55. Haha. Figures...thanks though, it is still progress...
Old 04-12-2014, 03:54 PM
Hey, Thanks Sloop!
That's kind of what I figured…12A contains the steering knuckle and 54 and 55…part of the steering knuckle.
Old 04-12-2014, 03:57 PM
Thanks.
Can you get those collars or bushings off the old control arms? Seems like a bit of heat would help. With tapered bits it also helps to rap them with a hammer…back up the bushing you want to get off the taper with a hammer and hit the bushing on the side away from the hammer. It ought to pop off just like a tie rod end on an old frog eye sprite.
nguyen1368
03-08-2005 11:28 PM
JAFO
07-27-2004 09:13 AM
Alex42886
10-11-2003 07:34 PM
MasterB
05-05-2003 04:12 PM
berger6696
02-24-2003 07:10 AM
Quick Reply: Need some control arm help
