Transmission Issues
The estimate says:
Perform transmission service including filter kit and gasket and then flushing the fluid.
SYN TRAN FLUID $122
ATF FILTER KIT $53
TRANS CONDITION KIT $32
Labor - $188
Good? No good? I'm clueless...
SYN TRAN FLUID $122
ATF FILTER KIT $53
Labor - $188
It's about a two hour job if the guy is any good at all, most of it is draining/dropping the pan and replacing the filter and pan.
It happened three times again tonight.
Warm day, driving for more than an hour, sitting in traffic, then very hard shift from 3rd to 4th. It felt like the engine could have dropped onto the road.
No engine or transmission codes. I guess the only thing left is trying to change the transmission fluid/filter. My mechanic talked me off the ledge yesterday, but if this doesn't work, I'm saying good-bye.
Oh I don't know. Replacing a transmission could/should give you a couple hundred thousand miles and some pleasure for 4-6 k $. The car loses tat or more on a trade in...very few people will buy a car knowing it needs a trans. I put a new trans in an 02 S6 at 100k...expensive but a better deal than a 50k new car.
I think the guy is pretty good. He found one code - and trans fluid was dark but not burnt. Found a P0117 fault on the temp sensor and recommended I replace it.
I looked back at an older estimate from the dealer. It says the "secondary radiator fan shorted and not working causing other fans to run excessively". Another dumb question, but would that cause the issue I'm experiencing (hard shifting only when the engine is warm, outside temp is warm, and accelerating after sitting at a traffic light).
#18
#20
Transmission control unit. Whenever it goes into limp mode (which is an controller state, not a mechanical situation), it should store a code. The only reason I can think of why it would go into limp mode but not have code stored is if it is off. So if there really are no codes (which I am having a hard time believing, as I mentioned) the unit is powered off.
This aligns with a heat issue. Maybe there is a control relay or something that heats up and cuts out? But even if the "shuts off" theory is correct, there should be ramifications with other control units; they have to be looking around trying to figure out why the TCU shut down.
So basically, I'm concerned about your shop. I'd want a second look from someone else.
