LED CONVERSION FOR FRONT TURN SIGNAL
I was finally able to remove the bulb from the OEM base for the turn signal. See pics attached for mod...
I used BMW PY24W LED indicator lights, removed them from the base and soldered longer pins. This next step requires a lot of patience, carefully remove the bulb WITH the surrounding holder from the base that attaches to the harness. You can use a small pry tool to gently lift it out, it is designed to come out if you do it right. Then using a hot glue gun I inserted the LED bulb and attached it to the base while guiding the pins through the base. Attach harness to the base and insert it back into the headlight housing and that's it! I did not receive an error on the instrument panel and it blinks at the normal rate that it should. Any questions, let me know.
Sounds easy enough. I've been trying to do this since forever. a few questions for you. Where did you purchase the longer pins that you attached? I'm assuming that this mod was pretty easy since you didn't write any complications that you encountered. Additionally, was getting to the bulb through the hood difficult? Any tips? Finally, I guess the fit was good and the bulb did not touch any interior parts of the headlamp assembly. You should take some pics to show it installed, maybe a video too : ) Thanks for posting this on the forum!
Thanks for posting back. I was looking at iJDMtoy.com and came across this
http://store.ijdmtoy.com/CAN-bus-PY2...-p/sku-431.htm
Wanted to purchase this and start your mod. They also have a plastic version.
http://store.ijdmtoy.com/Can-bus-BMW...24w-led-2s.htm
Was separating the LED from the plastic base difficult? Did you just pull or use a screw driver? Sorry for all the questions, just wanting to do some research before going all in. FYI. I talked to the importer for the Japanese bulb that is $250+
http://balanceit-tuning.com/products/accessories.html
He said that the he couldn't lower the price even on a group buy. So at least I tried.
Yea I tried the same thing $250 def not worth it, I removed the base by using a razor blade to cut through the glue by working it around between the base and led until it was loose. At that point you can twist it off until the pins snap, it doesn't matter where the pins break from bc you have to solder longer ones for the OEM base ( I purchased 2 LEDS from radio shack for that and cut them, see other pic) These are the ones I purchased from ijdmtoy:
