Is Audi a good car to own long-term when it goes out of warranty?
#21
I believe the paid Audi care from new is NOT a bargain, but it is also NOT a rip off. Overall, it is a small savings, lost only due to prepayment. I bought it, I like it, I'd buy it again. I hate the hassle and I am not taking it whilst it is in warranty to an indie, no matter how good or how cheap.
But that's just me.
But that's just me.
#22
The nice thing is, you don't have to buy Audi brake parts. Brake parts from the OE supplier (ATE, etc.) are much cheaper and usually the same exact part minus the pretty box with 4 rings. As for the labor cost, any indie mechanic can do brakes (assuming they have VCDS to retract the rear brake calipers) for a fraction of the cost. Even a shade tree mechanic can do the brakes with little trouble.
Why does my gut tell me that, because this is an Audi, it's going to be slightly more complicated...
#23
If the brakes on the A4 are anything like the disk brakes on my now defunct Chevy Z24, it's no harder than taking the wheel off, unbolting and sliding aside the caliper, pulling the disk of the studs (with, perhaps, a bit of encouragement), then performing the reverse for installation. Again, if the design is similar, I could replace a single brake disk in about 20 minutes and save hundreds of dollars in labor.
#24
No way Jose. I owned a B6 before this car and I spent about $9000 for maintenance in one farking year to keep it running. I therefore have decided to never own a German car out of warranty again.
#25
Oh man, let's see if I can remember all it needed:
Water pump/timing belt replacement
Steering rack replacement
Brakes
That comes to about $9K, doesn't it? Okay, no it doesn't but I can't recall what else. I handed over the records when I got rid of the car. It had a lot of little things happen and each time it would cost several hundred bucks between parts and labor. Keep in mind I'm not one to turn my own wrench. When the DIS started doing funny things I feared an impending electrical system malfunction, and when I started to smell antifreeze I decided to dump the car before anything else could go wrong.
Brakes
#27
Brakes
Brakes
#28
http://www.audizine.com/forum/showthread.php?t=184490
#29
I guess with that kind of mileage, you have to do an overhaul anyway, but if the previous owner did not take good care of the car, it can cost a lot more than expected. Hopefully you will have better luck with your next car.
#30
I have over 190,000 miles on my 1998 B5 A4 and I really can't complain about maintenance costs. This is mostly due to the fact that I do my own maintenance. Other than replacing the clutch, I've done all of the work myself so I've saved literally thousands of dollars over the last eleven years. You can buy parts online for a fraction of what the dealership charges. Here is what I've done outside of routine maintenance.
Clutch
Timing belt, water pump, and other belts (twice)
Front control arms
Rear wheel bearings
Front and rear brakes
Both front window regulators
If my B8 holds up as well as my B5 I'll be thrilled.
Clutch
Front control arms
Rear wheel bearings
