Removing clutch fan without special tool...
Old 02-12-2009, 12:44 PM
  #31
Joao's Avatar
Yes.
Old 02-12-2009, 12:49 PM
  #32
I was lost, now I'm found
myers1.8TQ's Avatar
When the first fan blew, I checked it and it was working fine. After the second, it was immovable.
  #33
myers1.8TQ's Avatar
Yeah tell me about it. Huge learning experience.
Old 02-12-2009, 03:38 PM
  #34
Aarononymous's Avatar
air hammer works every time in seconds....
Old 02-12-2009, 04:04 PM
  #35
lol, none of the other techs utilize that method at work..so easy
Old 02-12-2009, 04:12 PM
  #36
GNelson's Avatar
Default You get it figured out yet?...
When I did mine, I did it exactly as it says in the writeup. biggest allen that would fit in there, and just futz around with it until it comes off. I ended up holding the allen with my other hand. luckily mine was not on super tight. Admittedly I did have the lock carrier off at the time, so I had lots of space to work.
I kept second guessing myself as to which way it was threaded. I think it turned out to be normal.
Old 02-13-2009, 01:01 AM
  #37
aluminumpork's Avatar
Default Yup, just finished my timing belt job a few minutes ago...
fan came off easily after trying the allen trick again.
Old 03-30-2012, 02:30 PM
  #38
mrdiligent puravida's Avatar
Default 97 A4 Fan clutch removal
How do remove the fan clutch on my 97 Audi A4 quattro 1.8L turbo? Without the special tool? I know to use a allen wrench from the back side, I'm not sure what size allen it is, or if it's reverse thread or not? Has anyone put pictures or good links up on this yet? I have all data, but it's not much help )
Old 11-21-2017, 07:14 PM
  #39
dczar's Avatar
Default fan clutch
Originally Posted by aluminumpork
So I've pulled the plastic fan itself by removing the four little allen bolts and now I'm trying to figure out how I'm going remove the reverse threaded nut to actually pull the fan clutch off. I've looked around at some of the timing belt walk-throughs and they always say "I was able to figure it out by improvising". One said they used a little allen wrench to jam into one of the pulley's holes. I wasn't able to get anything to hold it as tightly as necessary.
Thanks.
I used a 12" adjustable wrench (have to turn clockwise) and used vise grips to hold pulley to backplate. Worked great came off easy. Improvision.
vtraudt
Audi allroad
02-21-2015 04:49 PM
KillA6
01-22-2009 09:44 AM
a6killa951
02-10-2008 01:23 PM
AWD2KS4
01-18-2008 12:10 PM
bogelo
12v V6 Discussion
05-19-2003 08:15 AM
Quick Reply: Removing clutch fan without special tool...
