Wolfgang vs Audi Wheels
Old 02-27-2014, 11:21 AM
Former Vendor
WolfgangCarCare's Avatar
Default Wolfgang vs Audi Wheels
Vehicle: Audi Q5
What's Dirty: The Wheels & Tires
What are we using:
Wolfgang Tire & Wheel Cleaner
Speed Master Wheel Brush
20" Montana Original Boar’s Hair Wheel Brush
Short Handle Tire/Wheel Brush
Equally effective - and safe - on wheels and tires.
Wolfgang Tire & Wheel Cleaner is a German-engineered wheel cleaner gel that clings to penetrate road grime on wheels and tires. The water-based formula is safe on all types of wheels, yet effective enough to penetrate and clean porous rubber. Wolfgang Tire & Wheel Cleaner is the only cleaner you need to clean and beautify your vehicle's wheels and tires.
Wolfgang Tire & Wheel Cleaner boasts industrial strength cleaning power in a non-caustic, water-based formula! Germany, the leader in environment-friendly research for the car care industry, has chemically engineered a new breed of cleansers to replace the outdated acid, butyl, or petroleum distillate based products. This new, surface-friendly cleaning technology is found in Wolfgang Tire & Wheel Cleaner.
Wolfgang Tire & Wheel Cleaner is biodegradable, non-toxic, non-caustic, and gentle on skin. However, this thick, concentrated gel packs quite a punch when it comes to quickly and easily removing brake dust, road grime, oil and grease. As soon as you spray it on, Wolfgang Tire & Wheel Cleaner goes to work loosening and dissolving tough road grime.
Wolfgang Tire & Wheel Cleaner was formulated for versatility, being equally gentle and effective on wheels and tires. Rest assured that Wolfgang Tire & Wheel Cleaner is safe to use on all kinds of wheels—including aluminum, painted, polished, anodized, clear coated and billet wheels. Emulsifiers in the cleaner capture dirt and dust on the wheel and allow them to be safely whisked away from even the most sensitive, expensive wheels without danger of scratching or spotting.
Wolfgang Tire & Wheel Cleaner contains emulsifiers, wetting agents and environmentally safe deep cleansers to loosen and remove all foreign particles clinging to your tires and wheels. It even penetrates below the surface of the rubber to extract deep, ground in dirt, brake dust, and tire dressing buildup. Tires and wheels will be left completely clean.
Wolfgang Tire & Wheel Cleaner is leaps and bounds ahead of other tire cleaners when it comes to our cutting-edge formula. Most wheel or tire cleaners rely on butyl or butyl ether for their cleansing power. Though cheap and highly effective, butyl is anything but safe. Butyl can stain aluminum, zaps moisture from skin on contact, and gives off toxic fumes. Wolfgang is proud to utilize German butyl-replacement cleaning agents in our Tire & Wheel Cleaner.
Benefits:
-Soft, nonabrasive 2 inch bristles
-Patented memory bristles regain their shape
-Chemical resistant
-Fits all wheel designs
-Reinforced, flexible stem
-Safe bonded tip
-Knuckle guard protects your hands
-Cleans the engine bay, too
The flexible stem bends around spokes to clean between the wheel and the rotor.
Montana Original Boar’s Hair 20 inch Wheel Brush is packed with real boar’s hair bristles. We chose slightly stiffer hairs from a more mature animal than what you’ll find in our boar’s hair wash brushes. The increased firmness makes the bristles more effective at removing the tough grime that coats wheels, like stubborn brake dust. The hairs are thoroughly cleaned before being attached to the handles. The long handle allows you to keep your hands clean and dry while you clean your wheels, bumpers, and grill. The long handle also enables you to clean deep in the wheel wells, where mud and grime are splashed as you drive.
It’s great for close-up scrubbing of your tire and wheel surfaces. This is a well-made, indestructible brush that is practical, efficient and safe for all wheels. It has hundreds and hundreds of densely packed bristles, feathered at the tip for gentle agitating of any wheel surface, regardless of delicacy. The bristles are sturdy enough to attack tough road grease and grime on your tires as well. It is constructed of alkaline- and acid-resistant, 2” fibers, mounted on non-slip, heavy-duty plastic handle.
Visit WolfgangCarCare.com for more information. Thanks for looking
Jiggie
08-30-2015 06:37 AM
Janryk
08-30-2015 02:12 AM
LuxuryAutoKSA
Vendor Showroom
08-29-2015 08:09 AM
Chigger
08-27-2015 11:07 AM
Quick Reply: Wolfgang vs Audi Wheels
