Lets talk about quattro
Old 01-10-2014, 09:35 AM
irenesbob's Avatar
Originally Posted by salvadorik
BMW builds 5 series on rear wheel drive platform and giving it all wheel drive powertrain does not necessary make it nose heavy, now does it?
Good point. The weight of the drive shaft itself (torque tube in the case of old Buick's) moves some of the weight to the rear. The A3 (with its transverse drivetrain) would be interesting to compare to a comparable BMW model.
Old 01-10-2014, 11:20 AM
q5q7's Avatar
zf 8hp gear box
4matic gear box
the 4matic is said to be fairly lightweight too. However it doesn't have a center diff. Both 4matic and quattro's front driveshaft is slightly to the right to clear the engine.
Old 01-10-2014, 11:37 AM
Banned
Mike_L's Avatar
The problem with 4Matic is that its got a fixed ratio split. Thats pretty useless on ice if your rear tires are spinning and the fronts are only getting 30% of the power.
Quattro can vary the split if I remember right, and I definitely know XDrive can (my X5M had a screen that showed where the power was going). Thats a much better way to go IMO.
Old 01-10-2014, 11:42 AM
q5q7's Avatar
Yup, 4matic is a electric controlled 4wd which is inferior to quattro.
Old 01-10-2014, 11:48 AM
Banned
in2dwww's Avatar
4matic simply applies brakes to the slipping wheel. Just like they do with their lane keeping assist. It's fairly rudimentary. We'll find out which approach is more robust 30 years from now. I'm guessing the Audi will still be on the road because the older MB's are rusting away before we find out.
http://www.benzworld.org/forums/w220...ust-spots.html
http://forums.mercedesclub.org.uk/sh...d.php?t=112830
http://www.benzworld.org/forums/w210...ust-onion.html
Old 01-10-2014, 11:54 AM
Banned
in2dwww's Avatar
And... 4matics have a higher ride height and less floor pan space. There's no "sport" suspension option that lowers the car to the RWD sport height. This is the downside to running the front axles below the engine and in front of the fly wheel like MB does.
Gavia
A7
39
07-31-2016 12:20 PM
hardipk5
12v V6 Discussion
10-01-2015 02:53 PM
saifxnyc
09-20-2015 11:34 PM
dsleedesign
TT (Mk3) Discussion
09-17-2015 08:29 AM
MonSoonHell
09-15-2015 07:14 PM
Quick Reply: Lets talk about quattro
