rns-e av input
Old 09-23-2013, 06:19 AM
Banned
JohnnyJ A6Q's Avatar
Default "ask yourself has you or louis told me anything"
Carterleeds,
I am a little bothered by your tone, I believe we spoke before on the phone {I could be wrong} and your attitude here is somewhat out of character, YOU want help and yet your acting like an ***, YES I did give you an option on how to get A/V input into your brother's RNS-E, I said plain and simple "go get a OEM TV tuner for that specific vehicle and use the RCA A/V inputs for what ever you want to input", do you want me to spell out the whole job for you, of just give you an option like I already did, a quick Google search will render great answers like these below.
OEM TV Tuner for B7 is ANALOGUE TV RECEIVER 4D0 919 146 D
Then a search on Ebay will yield you these items, then find the pin outs and make your own cables or buy one from Kufatec as I stated in my previous post.
http://www.ebay.co.uk/sch/i.html?_tr...at=0&_from=R40
http://www.ebay.co.uk/itm/06-AUDI-S4...item2eb2448f24
Also everything Louis stated is valuable information, it's part of what makes things work, and it also opens up people's minds to how things work which in turn an other person will come up with some ideas, if it was so simple, YOU would not be here asking for options, or maybe YOU would.
Also check out this thread.
http://audiforum.us/threads/a4-avant...retrofit.5665/
pin outs for rns-e
"two different pin outs for the TV tuner,"
Version 1)
Contacts which are not listed are not used.
1 – Ground
2 - CAN Bus Low (BOSCH) (from RNS-E Infotainment)
3 - CAN Bus High (BOSCH) (from RNS-E Infotainment)
4 - Audio screen (front) (not used)
5 - Audio output (right front)
6 - Audio earth (not used)
7 - Audio output (left front)
8 - Audio earth
9 - Screen earth (front)
10 - Video screen (front)
11 - Video output sync. (front)
12 - Video earth
13 - Video output (blue, front)
14 - Video earth
15 - Video output (green, front)
16 - Video earth
17 - Video output (red, front)
19 - Terminal 31
20 - Terminal 30
21 - L-diagnosis
22 - Audio output (–), rear right (not used)
23 - Audio output (+), rear right (not used)
24 - Audio screen (rear) (not used)
25 - Audio output (–), rear left (not used)
26 - Audio output (+), rear left (not used)
27 - Screen earth (rear) (not used)
28 - Com. Sync. (–), rear (not used)
29 - Com. Sync. (+), rear (not used)
30 - Signal (–) blue, rear (not used)
31 - Signal (+) blue, rear (not used)
32 - Signal (–) green, rear (not used)
33 - Signal (+) green, rear (not used)
34 - Signal (–) red, rear (not used)
35 - Signal (+) red, rear (not used)
36 - Video screen (rear) (not used)
40 - Audio input (–), rear left (not used)
41 - Audio input (–), rear right (not used)
42 - AV earth input (rear) (not used)
43 - S-VHS input (Y) rear (not used)
44 - S-VHS input (C) rear (not used)
45 - CVBS input rear (not used)
46 - Complete screen AV input rear
47 - Audio input (–), front left (not used)
48 - Audio input (–), front right (not used)
49 - AV earth input (front) (not used)
50 - S-VHS input (Y) front (not used)
51 - S-VHS input (C) front (not used)
52 - CVBS input front (not used)
53 - Complete screen AV input front
Version 2)
1 - CAN bus ground
2 - CAN bus Low
3 - CAN bus High
4 - Audio ground front
5 - Audio right front, positive
6 - Audio right front, negative
7 - Audio left front, positive
8 - Audio left front, negative
9 - A/V complete display front
10 - Video monitor front
11 - Not assigned
12 - Not assigned
13 - Not assigned
14 - Not assigned
15 - Video -C- front, positive
16 - Video -C- front, negative
17 - Video -Y- front, positive
18 - Video -Y- front, negative
19 - Vehicle Ground (GND)
20 - Terminal 30 (continuous B+)
21 - Not assigned
22 - Audio right rear, negative
23 - Audio right rear, positive
24 - Audio ground rear
25 - Audio left rear, negative
26 - Audio left rear, positive
27 - A/V complete display rear
28 - Not assigned
29 - Not assigned
30 - Not assigned
31 - Not assigned
32 - Video -C- rear, positive
33 - Video -C- rear, negative
34 - Video -Y- rear, positive
35 - Video -Y- rear, negative
36 - Video ground
37 - internally assigned
38 - internally assigned
39 - internally assigned
40 - Audio left rear, external connection option
41 - Audio right rear, external connection option
42 - Audio/Video ground rear, external connection option
43 - Super Video System rear, external connection option
44 - Super Video System rear, external connection option
45 - CVBS rear, external connection option
46 - Complete audio/video shielding rear, external connection option
47 - Audio left front, external connection option
48 - Audio right front, external connection option
49 - Audio/Video ground front, external connection option
50 - Super Video System front, external connection option
51 - Super Video System front, external connection option
52 - CVBS front, external connection option
53 - Complete audio/video shielding front, external connection option
54 - Not assigned
NOW was that so hard, now why don't you put away your attitude and take what people give you and think, instead of acting like we are wasting your time, WE are the one's here trying to help YOU !!!!
Johnny J J
Originally Posted by carterleeds
it clearly says a/v input and the question is, what options i have?!!!!
im sure many others have inboxed me congratulating me for calling out louis and his retardism unrelated info posting.
look in simple terms, if you cannot answer the question then dont reply. why do you feel the need to reply with unrelated info. and before you answer ask yourself has you or louis told me anything to do with an A/V instal or advised me if could install A/V inputs with or wihtout a tv tuner or options i have for an A/V instal?
Old 09-23-2013, 07:31 AM
carterleeds's Avatar
Originally Posted by JohnnyJ A6Q
Carterleeds,
pin outs for rns-e
Version 1)
1 – Ground
8 - Audio earth
12 - Video earth
14 - Video earth
16 - Video earth
19 - Terminal 31
20 - Terminal 30
21 - L-diagnosis
Version 2)
1 - CAN bus ground
2 - CAN bus Low
3 - CAN bus High
11 - Not assigned
12 - Not assigned
13 - Not assigned
14 - Not assigned
21 - Not assigned
28 - Not assigned
29 - Not assigned
30 - Not assigned
31 - Not assigned
36 - Video ground
54 - Not assigned
Johnny J J
thank you for the help.
you had helped me with my MMI a/v install, which i carried out successfully due to your DIY threads.
and i did not know if i needed a tv tuner or not because i had said "i dont think it has one" and no one helped me out, maybe i missed something or wasnt pushing the right button. i know everything now thanks to you guys about the MMI system but did not know if the RNS-E was any different or the same.
a little guidence of the system would of been helpful.
if you or louis replied with "you need a tv tuner for the av install" then i would of gone onto kufatec get a wiring harness or ebay it, same with the tuner and any other items i would of needed i would of googled but i had no where to start, hence not being able to google anything.
i googled RNS-E A/V instal and could not find one single thing, everyone talked about iphone/ipod etc which was of no use because i already have a iphone dock installed.
carterleeds
A4 (B7 Platform) Discussion
09-21-2013 04:51 AM
RobbC2
03-28-2006 01:44 PM
A3NDY
08-08-2005 09:48 PM
pixA4
11-06-2001 11:12 AM
Quick Reply: rns-e av input
