Audi allroad oil leak 2.7T
Old 01-25-2011, 08:31 AM
  #21
STL_allroad's Avatar
Does the updated oil cap really help that much? Where does all the excess pressure come from?
Old 01-28-2011, 11:22 PM
  #22
rylis's Avatar
Thanks for your inputs guys. I really do appreciate them all. Today I'm going to replace timing belt and check front camshaft seals for leaking. If you read all the forum you notice that my valve cover gaskets was replaced twice and I can assure you that there is no leak!!! I do hope to make some pic of my car to show how does it looks like underneath and find out are them camshaft seals my oil leak cause!!!
Originally Posted by robby777
This picture looks like the secondary airinjection system. Runs vaccum but different from your vaccum pvc system thats probally causing your problem. A known problem on the 2.7 motor is the valve cover gaskets leak because of sludge build up in the pvc system. If you reach behind the valve cover on the drivers side and feel oil thats probally your best bet to the source. The valve cover gasket can leak as well as the cam plug gasket. on the front of the passenger side of the engine and on the back of the driver side. ECS tuning has a decent kit that works. But youll probally have to replace a round diaphragm that is connected to the driver side of the intake y pipe right on top of the motor. It seizes up and causes back pressure to blow out the gaskets. hope this was helpful
Old 02-04-2011, 11:16 AM
  #23
alywyn01AR's Avatar
I am having the same issues, I am already noting the pressure oil leaks due to sludge from (gasp) regular oil being run in the engine. There is significant sludge and the synthetic comes out dirty on the dip stick, is there a cleaner I can run though the engine until I can get time to take it apart further? Ive seen cautions put on the forums about the oil system cleaners and these engines.
Thanks!
Old 02-04-2011, 06:01 PM
  #24
thejulex's Avatar
Thanks!
you could use seafoam, follow heir instructions for adding it to oil before normal oil change but don't drive as much as they tell you (I think it is 100 miles before change) but shorten that to like 25 or so and definitely DO NOT go hard on engine to avoid turbos spinning up. That should dissolve some of that sludge.
Old 02-07-2011, 03:42 AM
  #25
alywyn01AR's Avatar
Thank you very much, I'll go grab some and some fresh oil and a new filter. Much appreciated!
Old 02-07-2011, 12:25 PM
  #26
robby777's Avatar
Lubro moly has some great cleaner products I use every oil change
Old 03-09-2015, 07:22 AM
  #27
sobyx1's Avatar
Default Replace seals and gasket with breather hose
I believe this happened on my Allroad with the spider pvc breather hose getting clogged. If it causes oil leaks as the gaskets fail are they basically as good as blown and need replacement along with the breather hose? Ie Camshaft and valve cover?
Old 03-10-2015, 01:52 AM
  #28
PetrolBear's Avatar
If the octogon pipe was clogged you can have anywhere oil leaks.
Last year I had this... leaks at both turbos (seals inside gone!) valve gaskets + electrohydraulic actuators, half moons, plus, the O-rings at the front and back of the valve shafts. At least. I cannot recall exactly but I had a LOT OF leaks. Additionally, it was strongly advised to change several waterpipes due to oil contamination. Now my oil/water pipes are 80-90% new...and cost a LOT. So change your octogon pipe as a whole and check for leaks. Aftermath proplems (waterpipe damages) can be serious.
Old 03-10-2015, 01:56 AM
  #29
PetrolBear's Avatar
I do not know the seafoam but in general, such materials are very risky to the turbos!
My advise that worked: ride on cheaper (but specs matching) 5w40 oil in a normal way avoiding racing style driving, and change oil+filter after 1000km (600mile) at least twice or rather three times. Yes it is a bit work but it worths. My car had the same problem after purchase and it did helped a lot. Practically, it cleaned up the whole system. Hence, you can extract the bottom oil pan. There should be a lot of sludge (half inch dick at least).
If you have finances to do, I advise to change the big water cooler as well! It was also full with sludge. Afterwards, the oil (and engine) temperature dropped 10-12 Celsius. It means, driving the fullsynth 5w50 my oil temp never exceeded the 120 mark (at 30-35celsius on the autobahn, driving at 130-160kmh/h with many accelerations)
The oil temp should normally show around 100-103 (at the left white mark from the center or the needle slightly exceeds of... 0,5mm) if everything is clean an OK - and you run on 5w-50 fullsynth.
Lastly, 5W-50 fullsynth oil (Mobil1) drops arund 5-7 celsius of the engine temperature, compared to a good brand of halfsynth 5w-40
Luke McNeley
09-04-2015 02:12 PM
jbicski
08-30-2015 12:48 PM
Janryk
08-30-2015 02:12 AM
ign 5
08-29-2015 02:45 PM
ECS Tuning-Audi
Audi allroad
08-27-2015 11:18 AM
Quick Reply: Audi allroad oil leak 2.7T
