Audi A2 Discussion forum for the Audi A2
manifold pressure fault
Old 10-05-2009, 04:01 AM
sam 901's Avatar
Default manifold pressure fault
i had a problem with my audi a2 took it to local audi garage they put it on a dianostic machine and found well ill put excatly what they put on invoice........... checked egr valve function/voltages - ok- breather valve damaged ..... basic settings not set up of egr valve n18. carried out basic settings of egr engine light now out.checked mvb 75 intake manifold pressure difference not reaching spec of at least 45mbar only 20mbar suspect manifold pressure fault.
they do not know what it could be without sripping which will cost quite a bit of mobey anybody any ideas thank you
Old 02-11-2012, 01:24 AM
labbonoxeo's Avatar
I added some clarification in the first post about LED lamps turning on immediately: yes usually light will come out of a CFL fairly quickly (within one second) but the brightness can be significantly less than what it is once they have warmed up.* Even recently-purchased CFLs
leds lights
Old 11-29-2012, 02:05 AM
dobara's Avatar
eggsngrits
12-08-2021 06:58 PM
Aman Singh Parhar
11-29-2016 05:03 AM
Cmmartin23
26
08-23-2016 04:44 PM
saifxnyc
9
11-30-2015 12:32 PM
Georgi_Kirov
09-15-2015 11:11 PM
Quick Reply: manifold pressure fault
