Brakes Discussion Discussion forum regarding brake tuning, upgrades and questions
TTRS brakes
Old 03-29-2014, 02:47 PM
Tim Allen's Avatar
Default TTRS brakes
any advice regarding replacement of TTRS front brakes? I need to replace rotors and pads. Rotors are warped. should I replace with something else that is more durable?
Old 03-29-2014, 02:52 PM
Tim Allen's Avatar
Default TTRS front brake replacement ?
Any suggestion regarding replacement of TTRS Front Brakes?
Old 04-01-2014, 08:27 AM
Just Me's Avatar
What's the question? Replace pads? What problem are you solving?
Grant
Old 04-02-2014, 10:54 AM
EV Cruz's Avatar
U should . Try Tarox or Loba replacement disc. They are ligher and more durable.
Old 04-02-2014, 06:22 PM
Tim Allen's Avatar
Need to replace warped rotors and will replace pads too.
Old 04-07-2014, 02:17 PM
Just Me's Avatar
Then see below.
Advice? Lubricate sliding caliper pins. Make sure pads are in straight. Think OEM pads - they have the fewest interactions and are a good trade off (yes, dust sucks, live with it). Change your fluid when you do your brakes. Make sure pistons are moving freely - that's often a source of deposits and subsequent pulsation/grabbing.
G
Old 04-14-2014, 07:58 AM
EV Cruz's Avatar
Yes of course! They are lighter than OEM , Unsprung weight is greatly reduced. I mentioned a couple on this thread check them out.
Old 04-15-2014, 09:32 AM
Just Me's Avatar
so we want more thermal mass but lighter weight, eh?
Discuss
Grant
Old 05-09-2015, 12:26 PM
Tim Allen's Avatar
Default TTRs brake issue
i am still having problems with TTRS Brakes. pulsation with application of brakes and believe rotors are warped. Had them turned once which fixed the problem but now back after only few thousand miles. I have not had on track so only routine driving. I think I will have to replace. any suggestions for replacement of front TTRS brakes. Would S5 brakes work and be an improvement?
TA
Old 05-13-2015, 11:52 AM
EV Cruz's Avatar
You should try racingbrake.com. I going the same route when my breaks wore out.
But since they have a recall on front brakes( front calipers have dampers looking like two cylindrical oversized bottle caps protruding out of the calipers on the inner side ) I never had any problem with the OEM brakes but I have upgraded to stainless steel brake lines from Goodrich . No more spongy feel.
Thanks a Bunche
tsegreto
10
11-21-2018 03:13 PM
sda1906
09-22-2014 04:14 AM
boricuaA3
Audi A3 / S3 / RS 3
06-18-2009 02:38 PM
jmsod
07-17-2004 07:47 AM
audi devil
06-27-2002 06:53 AM
Quick Reply: TTRS brakes
