Brakes Discussion Discussion forum regarding brake tuning, upgrades and questions
rear caliper securing bolts
Old 10-23-2013, 08:35 AM
joetow's Avatar
Default rear caliper securing bolts
hello any ideas on how to remove the two allen key bolts 8mm that secures the caliper to brake disc/hub on the rear , the bolts are badly distorted as somebody previously used excessive force or a over zelous air gun the shape off the internal hex is no longer there ? i was told irwin tools dos a special socket that is used to grab the external part off the bolt & undo it ?
i have not yet tried this method has any one experienced this problem on the a4 audis im sure it must be a common problem if anyone has tried this method using irwin tools sockets could you let me know wot size socket fits exactly over the allen key bolt
as im stuck at the moment on this problem i have soaked the nuts for a week using penatrating oil also used a blow lamp with out no success any help hints tips gladly welcome thanks joetow....
Old 11-05-2013, 05:08 AM
Just Me's Avatar
Are they flush or protruding? Might try either vice-grips or EZ-out or, gulp, drill'em then EZ-out 'em.
Not my specialty.
Grant
N'Syncro
33
02-16-2020 03:12 PM
Cmmartin23
26
08-23-2016 04:44 PM
soonerjeepman
Brakes Discussion
05-08-2016 07:12 PM
vwleadfoot
Audi Original "S" Cars
12-24-2015 06:07 AM
Optimusglen
09-08-2015 06:57 AM
Quick Reply: rear caliper securing bolts
