Interesting MAF vs. RPM data...
and throttle position IIRC (missing anything else?).
So if what you're saying is true, whenever the ECU sees 5v coming from the MAF it automatically starts calculating the mass of air entering the engine using a different formula. Hrrmmm, maybe this'd be a good topic to bring up on the S2forums?
No Bozos!
Don't even need TP, you can use vacuum.
<center><img src="http://members.verizon.net/~vze4phja/images/airbox.jpg"></center><p>airbox--elbow--throttle plate--manifold
All that shows is that the modified S2 that the data came from hit 800 kg/h MAF at ~3500 RPM.
The stock MAF output is NOT linear to flow, and maxs out at 800 kg/h (from the factory specs) or about 385 CFM.
CK NYoC
12v V6 Discussion
09-28-2004 12:18 PM
'00 Santorin S4
04-12-2004 02:59 PM
s4what?
15
02-14-2003 11:14 AM
pattersom
21
12-15-2002 11:24 AM
cpayne
06-15-2002 11:14 AM
