View Poll Results: Do you prefer the OLD FAQ?
I want the OLD FAQ back! 4 100.00%
I like the NEW FORMAT 0 0%
Voters: 4. You may not vote on this poll
Closed Thread
Old 03-04-2006, 07:17 AM   #421
EricBss7_CT
Account #: 74931
Default TSW Volcano (Working Picture)
2001 A4 1.8tqms
Engine/Transmission:
GIAC Flashed 2 Program ECU (X and Stock Mode), Borla Cat-back exhaust, Bailey Diverter Valve, AWE DTS, B&M Short shifter, PureMS Snubby
Suspension:
Vogtland Springs with Bilstein Sport
Exterior:
18" TSW Volcano Hypersilver Rims, 225/40/18 Nitto Neo Gens, 20% Tint, E-Codes, RS4 Grille, Debadged and rebadged with older quattro badge
Interior:
Autometer Phantom Boost Gauge, Greddy Turbo Timer, Landspeed Aluminum Shifter Plate, Momo airleather knob and Momo alcantara shift boot, Coin holder mod, Sunglasses holder mod, Phatnoise, Harmon Kardon Drive + Play, 6.5" Pioneers on rear deck
Peter: Sweet I'm gettin an Audi.
Brian: Peter, that says Audit.
Peter: No no Brian it's a foreign car, the T is silent. Sweet I'm gettin an Audi!
EricBss7_CT is offline
Old 03-10-2006, 09:54 AM   #422
TwentyValveB5+S4
Account #: 87200
Default Dual-mass flywheel inspection guidelines for 1.8t
2008 RS4, 2001.5 AWE Stage 3 S4
TwentyValveB5+S4 is offline
Old 03-12-2006, 07:26 PM   #423
TristanP
Account #: 20538
Default The B5 FAQ sig pics (new addition on 5/7/08)
AudiWorld is now hosting the pics - instructions on how to add them to your sig are here.
Â*Â*
Â*
Â*Â*
Â*
Â*
Â*
TristanP is offline
Old 03-22-2006, 06:24 PM   #424
RS41AB
Account #: 59187
Default Flik Wasp (Anthracite)... yes 18" will fit with 13.1" rotors and Boxster Calipers
RS41AB is offline
Old 03-22-2006, 06:33 PM   #425
RS41AB
Account #: 59187
Default 17" x 7.5" Moda R6
RS41AB is offline
Old 03-22-2006, 06:45 PM   #426
RS41AB
Account #: 59187
Default Borla (v2)
[list][*]http://www.awe-tuning.com/pages/shar...=1&PEI=2&PP=a4
RS41AB is offline
Old 03-27-2006, 10:50 AM   #427
andysprague
Account #: 25673
Default OEM lug bolt size = 14 X 1.5 X 28mm with a ball seat
andysprague is offline
Old 03-27-2006, 08:57 PM   #428
A4SilverT
Account #: 73690
Default If you only need one or two new tires
What if you blow a single tire? Or wear out the two front tires due to a bad alignment? How many tires should you replace? This has been a contentious issue for a long time on AW, and there seems to be no definitive answer. VAG has caused some of the confusion by their vague statements in the owner's manuals.
First, here's what everyone agrees on. You should install the same size, brand, and model for all four tires so you have the same tread pattern. Doing anything else will affect how the vehicle handles. Don't mix winter and summer tires; if you're going to use winters, use them on all four wheels.
Second, Audi says in their owner's manuals that if you replace two tires, put the new tires on the front wheels. Recent research by Michelin suggests that this is wrong, even when the manufacturer says it. Michelin says (and Tire Rack confirms) that in wet conditions that could cause hydroplaning, having the greater tread depth of the new tires in the rear makes recovery from hydroplaning easier. Detail on this research is available on Michelin's web site and on Tire Rack's site in the tire tech section.
But what if you want to put one brand new tire (with a tread depth of 10/32") into a mix of older tires with less tread depth? Here's where the confusion starts. From the 2001 B5 owner's manual (for quattro cars):
"All four wheels must always have the same rolling radius. Different tires on the front and rear wheels may impair vehicle control and will damage the All Wheel Drive because of the constantly different wheel speeds. The proper function of the system is not affected by unevenly worn tires." (page 177)
What does "unevenly worn tires" mean? If it means that the outside tread or inside tread is more worn due to under- or over-inflation, that makes sense. But if the overall tread is more worn, that would change the rolling radius. Each 1/32" of tread wear causes 1/16" change to the diameter of the tire, and the circumference of a tire is its diameter times pi. So wear your tires halfway down (10/32" to 6/32") and you've changed the diameter of the tire by 1/4". You can use tire size calculator to see how much that will affect your speedometer for your setup, but that's roughly a 1% change.
Tire Rack asserts that Audi owners' manuals allow the tires to be "within 4/32-inch of each other in remaining tread depth." Sounds like a good rule, but that's not in the 2001 manual. And Audi mechanics aren't reporting a flood of damaged differentials; in fact, the differentials seem to hold up very well if given minimal care.
So if you blow a tire beyond repair, what are your options other than buying four new tires if you want to keep tread depth within 4/32"?
First, if you had a spare of the same brand and model that you put into your tire rotation pattern, your spare will be close in tread depth. However, if the tire tread is directional, using a five-tire rotation may involve more effort than you want - at some point, you'll have to remount a tire. And you'll need to rotate the tires frequently, no more than 5000 miles between rotations, or whatever it takes so that the variance between tires is no more than 1/8".
Second, you can buy a new tire of the same brand and model from Tire Rack (and possibly elsewhere, but Tire Rack advertises the capability) and have them shave it to match for an extra $25. This assumes that you can measure correctly to give them the proper tread depth and that the tire manufacturer still produces the tire model in question (meaning that they haven't changed the tread pattern while keeping the same name).
The good news is that most tire failures aren't so catastrophic that it isn't a simple matter of plugging a hole. And if someone slashes all four of your tires, your insurance will take care of your new set, less deductible.
So what this comes down to is whether you can still buy a tire of the same size, brand, and model as your existing tires. Tire manufacturers will generally keep making a tire model for 4-6 years. If you can get the same model tire, then have that new tire shaved to match the existing ones. If you can't buy the same tire, then you're stuck with replacing all four regardless of tread depth unless you can use your spare.
A final thought about replacing one or two tires is that it only makes sense if the existing tires are reasonably new. A brand new tire usually has a tread depth of 10/32". At 2/32" tread depth, a tire is no longer serviceable. Depending on the model of tire, you're going to start seeing performance degredation at 4/32", especially in wet situations. So if your existing tires are 5/32" or less you're going to need a whole new set soon anyway. Might as well bite the bullet and just get four new ones.
_______
2001 A4TQM
GIAC X-Chip
710N BPV
APR catback exhaust
H-Sport front and rear anti-sways
Koni Adjustable Yellows
A8 big brake kit
Carbotech Bobcat pads
Kumho Ecsta Sports
AWE Tuning Center Vent Boost Gauge
VW Taschenlampe
Link to the A4 B5 FAQ
A4SilverT is offline
Old 03-28-2006, 01:20 PM   #429
JA4T
Account #: 88817
Default Autotech
JA4T is offline
Old 03-30-2006, 06:52 PM   #430
S4iowa
Account #: 36175
Default Camber adjustment options (factory is non-adjustable)
UPDATE: 10/4/2008
Adjustable options are
Stern (from PureMS)
BHR
BHR
CPT
CPT
K-Mac upper control arm bushing replacement kit.
CPP is out of business, but would still be available used
CPP adjustable replacement control arms.
Current:
2004 S4
No Warranty:
66K Fuel filter $45
67K Motor mount $200
67K Coil pack(s) $40*2
67K Window regulator $100
71K Battery $135
2003 TT 1.8T
No Warranty:
50K Hazard Switch $50
Past:
1998 A4 1.8TQMS
B6/7 S4 Hawk Pad part number update!
Should no longer need to do the below anymore:
How to modify C5 A6 Hawk pads for use in the B6/B7 S4 or B7 A4
S4iowa is offline
Closed Thread
a4, audi, b5, bose, decoder, door, driver, front, removing, seat, size, speaker, speakers, w12, work
