| Welcome to AudiWorld! | ||
| Q5 Discussion Discussion forum for the Audi Q5 SUV
Sponsored by: Audi ![]()
#1 | ||
2012 Audi Q5Join Date: Jan 2012
17" wheels are rare, so you probably won't find someone who's gone from 17" to 18 or 19.
I've got 19" and the handling is very good. I've heard that when you get to 20" and higher, the ride starts to get pretty harsh. |
2011 Audi Q5Join Date: May 2011
Be sure to check clearances before you do !
The wife wanted 'different' for her Q5 and so we did some 20's that looked great and fit great (sitting still) but because of the control arm on the front that is just a smidge over the tire on our 19's, they rubbed on top as it heated the tire at spped.... so then went with the audi 20 multispoke's that are on there now - they are basically the same height as our 19's in the garage... just a little more wheel and a little less sidewall is all... does it handle better with the lower profile tires ? I guess a bit, but not enough to have great expectations... if you are in the DFW area - I have stock 19's with tires ready for you
Brilliant Black 2011 Q5 20T P+,MMI,B&O,20" Multi-spokes Pkg w/ Goodyear Eagle RS-A 101V tires http://forums.audiworld.com/album.ph...ctureid=233007 FOR SALE, magnaflow mufflers, Sound and fury here: http://www.youtube.com/watch?v=Ec7idI1BRHI
I've got 18" and would prefer 19". Anything over that will make the ride stiffer than I'm willing to tolerate.
Recover, Rehab, Rehome English Bulldog Rescue |
The larger the wheel (lower profile tires), the more direct the steering and road feel will be. The opposite is true also (smaller wheel + thicker tires = softer feel).
Fuel consumption will be based on weight of the wheel/tires together. It is possible to get wheels/tires that are lighter than your current set, which then will result in better economy. Width of the tires (the first number, usually triple digits, in the tire spec) and rolling resistance (the rubber compound) also come into play for fuel economy. Then there is looks factor (which is all subjective)
//2012 Q5 Phantom Black Pearl / APR / Caractere / Remus / HRE / KW Suspension |
#6 | |
Quote:
Thanks good to know!! |
#7 | |
Quote:
Yes indeed, pretty rare. So if I got right, if changing I should go for the 19". Streets on my city are not smooth and have a lot imperfections & bumps, so I believe 19" will work and keep ride comfortable. |
#9 | |
Quote:
Thank you, it's a shame I'm not even near to DFW. |
