Go Back   AudiWorld Forums » Audi Models » Audi A8 / S8 » A8 / S8 (D3 Platform) Discussion
Old 05-05-2012, 07:55 PM   #1
perlfather
1991 Porsche 911
My Garage
Default some type of air pump from front left does not shut off
After turning the car off tonight (70k miles) what sounded like some type of air pump type noise continued. Could not figure out what it was or how to turn it off. The noise sounds almost exactly like an air pump and comes from the very front of the left side, under the hood, close to the front bumper and the wheel well. Any ideas on what it could be?
perlfather is offline   Reply With Quote
Old 05-05-2012, 08:07 PM   #2
Brozee
2007 Audi A8
My Garage
Brozee's Avatar
Sounds like your compressor, I suggest unplugging your battery to save it from dying. It's either that or I believe your air strut is leaking and the compressor is working to keep it inflated
2007 A8L 6.0L W12 Fully loaded every option
Mods: LED's all around, HOEN fogs, hardwired Escort 9500ix, 2011 Maps, MMI v46.1
VCDS Mods: belt chime delete, remote window control.
2005 A8 4.2L w/ all packages.
Mods: LED's all around, HOEN fogs, hardwired Escort 9500ix, limo tint, 2011 Maps, MMI v46.1 VCDS Mods: belt chime delete, remote window control.
Popular Topics & Help for Noobies:
Oil Change Procedure
Disable TPMS System
AMI Installation
AMI Update (Phone not pairing)
Remote Window Control
Enable Hidden Menu & Enable Battery Meter
Fog Light Replacement
City Light Bulb Replacement
Door, Trunk, & Glove Box LED Change
Cabin Air Filter Change
Maintenance & Common Problems
Brozee is offline   Reply With Quote
Old 05-06-2012, 05:12 AM   #3
idf
2007 Audi A8
My Garage
How long does that happen for?
Occasionally when I turn my car off I hear a motor running for 6 or 8 seconds and then stops.
idf is offline   Reply With Quote
Old 05-06-2012, 08:01 AM   #4
mishar
2005 Audi A8
mishar's Avatar
It is compressor. Right behind your left front wheel. You have a leak in the system, hopefully not a strut. If everything is OK you virtually never hear compressor working.
mishar is online now   Reply With Quote
Old 05-06-2012, 04:09 PM   #5
perlfather
1991 Porsche 911
My Garage
Default and the next day...
The compressor turned off by itself after about 5 minutes. (No need to disconnect battery)
The next day everything seemed OK. So - did the compressor get stuck in the ON position or was there a leak that has closed due to a different temperature or some other reason the next day. No idea. I'll report back on developments.
Thanks for the information so far!
Old 05-06-2012, 04:19 PM   #6
idf
2007 Audi A8
My Garage
Quote:
Even for a few seconds? I thought that was normal? Is what I am hearing in fact the compressor, it makes a sound similar to a power tool.
Old 05-06-2012, 07:22 PM   #7
mishar
2005 Audi A8
mishar's Avatar
I have this car for abut 1.5 years and I heard it may be twice. Sounds more like a loud fridge than power tool. I hope this statement wont bring some bad luck.
Old 05-06-2012, 07:28 PM   #8
mishar
2005 Audi A8
mishar's Avatar
If something got stacked it is the relay. If it happens again pay attention if you hear pressure relief valve. If there is no leak pressure will get too high and will be relived by the valve. In that case it is stacked relay. Otherwise it is a leak.
Old 05-12-2012, 10:57 AM   #9
perlfather
1991 Porsche 911
My Garage
Thank you very much mishar (is it Misha R?) for this great answer! Indeed the 3rd time this happened I heard a clear pressure release valve open and the pump shut off. Based on this insight I took the car in and suggested/asked that they replace the defective relay (unless they find something else wrong). Should have it back on Monday.
Old 05-12-2012, 11:12 AM   #10
mishar
2005 Audi A8
mishar's Avatar
It is Misha R.
