| Welcome to AudiWorld! | ||
| A6 / S6 (C5 Platform) Discussion Discussion forum for the C5 Audi A6 and S6 produced from 1998-2004 |
#1 | ||
2005 Audi A8Join Date: Dec 2011
While it's possibly the coil packs for 2 and 4, those codes are not a "for sure" indication. Swap them to other cylinders and see if the misfire detection follows - that would be sufficient data for me to replace them.
She wouldn't possibly have a aftermarket ECU tune on the car, would she ?
2001 A6 2.7t 6-speed; ECU & BiPipe by APR |
#3 | |
I'll try that and update. And no, no upgrades yet
It's done a squillion miles so I'll just keep it stock for now I think...![]() K9 Quote:
Reason I ask is that my APR chip has some annoying hesitations at certain engine temps and RPM that one might mistake for misfires.
I agree- I would swap coil packs, but I would swap one at a time. I've seen one coil pack throw timing off on another cylinder. You may only have to replace one, plus moving two at a time introduces more chance of mis-diagnosis.
Do you have a green-top coolant temp sensor? Coils will cost $30-40 on your car, as I believe they are the screw-down type, but my mom has the same year/engine and I think I've only ever replaced one coil on her car - much more reliable. |
I'll try the 'one coil swap' and see what VCDS gives me. $30-$40? where from? The only ones I could find on Ebay were $90, and that's USED!
Will check coolant temp sensor too, but why the question?K9 |
2005 Audi AllroadJoin Date: Aug 2004
An interesting fact: coils on my C5 4.2 are cheaper than on my Mazda 3. Both from their respective dealers.
Wow - looks like these units have gone up in price a little. They are $50 on ECSTuning.com - but they'll take a while to get to you. The dealership should have them around the same price....$40-60 each.
*edit* - I ask on the coolant temperature sensor, just because it is a cause for all sorts of strange ghosts in this car. My first thought is always the coils for the cylinders, but just something about the situation makes me think CTS as a second thought ...not sure why...it's good to have the green sensor either way. Last edited by jseklund; 05-09-2012 at 11:19 AM. |
#9 | |
I'll do the swap first, then check prices and update on here...
K9 Quote:
#10 |
2001 Audi A6Join Date: Jan 2011
i have a 01 2.7t that i just put the apr tune on and now it hesitates and sputters under full throttle and then the check engine code will come on for random misfire and for cylinder 3 misfire. tried new plugs and it was find for a day then back to the same problem. any ideas?
| 2001, 27, 27l, 27t, a6, apr, audi, chip, coolant, hesitation, load, location, misfire, sensor, temperature |
