| Welcome to AudiWorld! | ||
#1 | ||
Get a code reader and read any stored codes.
My code reader will only read codes when the engine is running. The battery has been disconnected too since the last time it ran. I'll try to get a code reader that will tell me something..
Passenger-side floor, under the carpet, right where the slope starts is the ECM location IIRC. Check to make sure coolant didn't get it.
Thank you cerverappz!!! I know coolant got to it. Just gave up and brought it to a shop today. There scanner would not communicate with the car. I'm starting to believe the problem is the ECM. Can this be replaced easily?? I know I can swap the parts but will changing ECMs cause problems??
You/Audi will need to reprogram the immobiliser in order for the new ECU to recongize the new key code.
First check to see if the ECU is getting power. When you turn the ignition key, do you see the Check engine light come on? If not them check to see if the fuse and/or relay to supply power to the ECU is working. |
This car (The C4 A6) will now start and fire after a little tlc. But the car does not idle, and it quickly dies. The car was flooded with coolant unfortunately. Anyway I can get a new ECM at the junkyard, but would the car still start if thats the problem?
If the car starts, then the ECU is working. Can you keep the car running by giving it more gas? Replacing the ECU will require that you reprogram the immobilizer to recongize your current key. Since the engine does starts I would check all relays and verify that you didn't blow any fuse.
I can keep the car running using the gas pedal, but not easily, almost like it fluctuates around the rpms it wants. If I'm not giving it just the right amount of gas, it dies on me. I'm confused why the shop couldn't get any codes.. I really don't wanna bring it to the dealer but i feel like I don't have a choice
#10 |
Shop couldn't get any codes because their code reader can not read Audi/VW.
You can buy a code reader for Audi/VW or ask the shop if they have one. |
| 28, 97, a6, audi, battery, c4, crank, quatro, quattro, replaced, start, wont |
