Old 02-12-2012, 10:15 AM   #1
reesea17
2001 Audi S4
Default Gas Milage drastically decreased
Within the last two months I have seen a drastic decrease in my fuel economy. I figured it may be caused by a bad purge valve as I got an engine light a while ago pointing towards emissions/purge. I recently replaced the purge valve after a long time trying to find the little sucker, and don't see much improvement in the milage. In between the time I had to have the tranny and clutch swapped out and that hadn't done anything to hurt or fix the problem.
I realize this is all very vague in detail but I was wondering if I might be able to get a couple of y'alls input on what possibilities I might be able to try out in order to fix the problem. I went from getting about 19-20 mpg city to 12-13 mpg city. I need to fix this problem as it is currently nearly costing $50 to fill up the tank each time. Thanks in advance.
reesea17 is offline   Reply With Quote
Old 02-13-2012, 05:51 AM   #2
thejulex
There are usually several culprits:
1) your EGT sensors failed (common on 2.7t) and engine is dumping fuel all the time
2) your O2 sensors are on their way out, causing you to run rich
3) your MAF failed and is giving wrong readouts
Usually it is #1, sometimes #2, rarely #3 unless you have bosch maf which is known to fail frequently.
thejulex is offline   Reply With Quote
Old 02-13-2012, 10:48 AM   #3
akop18
2000 Audi S4
Sounds similar to my buddys B5, his EGT sensors failed like thejulex said, I would start there.
akop18 is offline   Reply With Quote
Old 04-25-2012, 05:43 AM   #4
Sigiwald
I have bad EGT's and I still see 20-22 mpg. Could be your O2's
Sigiwald is offline   Reply With Quote
Old 04-26-2012, 06:26 AM   #5
COMPUTEK::WMS
2001 Audi S4
Are you stock or Stage 3?
I am currently stage 3 with I believe the green top injectors and I have pretty much always got 12-13 MPG in the city and 18-19 MPG Highway for years even with getting new EGT and O2 sensors.
Engine-AWE Full Stage 3 Kit w/o manifolds,GIAC X and XR M Box 5 prog. w/flashloader,IC w/shrouds,DP w/test pipes,RS4 Eng. Mnts.,RS4 Tran. Mnts.,Millitek 3" Catback Exh.,Evo Intake,APR Snub Mnt.,Forged Diverter Valves,Samco Sport Blue Silcon Hose Kit
Driveline-CM Stage 4 Clutch,CM LW Flywheel,Stasis Center Diff.
Brakes-Alcon/Stasis 6 POT Calipers, 14" 2 Piece Rotors,Stasis Rear Brake Upgrade,Goodridge Stainless Steel Brakelines
Suspension-Bilstein PSS9 Coilovers,Nuespeed 19mm Rear Sway Bar,AWE DTS
Accessories-19" Neuspeed RS10 Silver Forged Rims,AWE Vent Boost Gauge,AWE Pedals,Alcantara Shift Boot,Valentine 1 Hardwired,Pioneer AVIC-D3 w/bluetooth and iPod connector,Alcantara Interior,Clear Corner Mod,RS4 Bumper,CF Hood (Painted),M3 Lip,RS4 Grill
COMPUTEK::WMS is offline   Reply With Quote
Old 04-27-2012, 01:06 AM   #6
papuc (MMI S4)
I would look at the 02s first, unless you're getting a code for EGTs.
2001 Audi S4 6MT
GIAC-X
Bosch 710n
Bilstein Shocks w/ H&R Springs
AWE Vent Gauge
V1 Hardwired w/ ToyGuy concealed display
Greddy Turbo Timer
Stage 1
Custom 3" Milltek exhaust on the work bench.
Piggies, whenever I get to it.
Maintenance needed:
Timing Belt. In 2K miles and counting.
Oxygen Sensors.
papuc (MMI S4) is offline   Reply With Quote
Old 04-30-2012, 06:51 AM   #7
reesea17
2001 Audi S4
My question here is whether failing EGT sensors would give me a check engine light? Or would I only be able to read it using a VAGCOM?
Old 04-30-2012, 06:52 AM   #8
reesea17
2001 Audi S4
My S4 is stock except for a Vented Air Box (Darintake) and a recent transmission replacement.
Old 05-07-2012, 02:09 PM   #9
papuc (MMI S4)
EGTs won't necessarily throw a code. Best bet would be to scan it using Vag-Com.
2001 Audi S4 6MT
GIAC-X
Bosch 710n
AWE Vent Gauge
Greddy Turbo Timer
Stage 1
Maintenance needed:
Oxygen Sensors.
Old 05-14-2012, 05:01 PM   #10
S4incter
Quote:
Agree, EGT is just a safety margin. Too hot of EGT will cut timing... I don't even run them and they are tuned out. If O2 sensors are getting lazy, could do it. But I would check your coolant temp sensor. That would tend to dump more fuel than any of the above....
Current:
~2000 Audi S4 black/black Billet RS6 Turbos
~2004 Audi A6 black/black S-Line
~1990 Vw Corrado ABA16vT Precision 58/57
~2008 Aprilia SXV450
~2003 Kawasaki Z1000
~1978 Yamaha 1100 Cafe Racer
Sold:
~1991 VW GTi VR6 Eatoncharged
~1993 VW Passat 16v
~2003 Audi A4 Convertible
~1996 CBR 600
S4incter is offline   Reply With Quote
a4, audi, b5, bad, bosch, code, decline, egts, fuel, gas, green, injectors, milage, mileage, o2s, purge, s4, valve
