Go Back   AudiWorld Forums » Audi Models » Audi allroad
Old 05-04-2012, 02:17 PM   #1
joenok
joenok's Avatar
Default Anyone seen this? any thoughts?
I was wondering if anyone else has had this problem. -I have a hunch it comes from the ride height sensors, but i donŽt know. I also read somwhere that this can happen if the car is parked unflat -like in terrain or something.
I used to get this once or twice each month, sometimes more, sometimes less.
Today it came on all 5 times the car was started.
Car has been sitting in level 2 for over a month. -No deflation or other kinds of trouble with the air ride.
I start the car, as soon as i step on the brake to switch to D/R, these buddys light up my dash, all at the same time.
I am thankful for all tips and thoughts, so I can start troubleshooting.
Thanks!
Jorgen Enoksen
2003 Allroad TQ
X 75ŽAudi 50, 1993 Audi S4tq, 1997 Audi S6tq, 1996 Audi S6tq, 2000 Audi S6v8q, 2002 Audi A4tq, 1997 A4tq)
joenok is offline   Reply With Quote
Old 05-04-2012, 04:05 PM   #2
Kneale Brownson
The (0) one in the center is your brake pad warning. The electronic stability program uses the brakes, so that's probably why that one shows.
Kneale Brownson is offline   Reply With Quote
Old 05-04-2012, 05:00 PM   #3
joenok
joenok's Avatar
Thanks.
I know what the lights mean one and one, but the fact that the come on like they do, makes me believe this is some kind of safe-mode for the suspension.
ABS and ESP use a lot of common sensors, could there be a wheel speed sensor or something?
Braking compound warning came on not that long ago, I never thought that could have anything to do with the rest of the warnings. However, like I said, it does come on the same second i step on the brake..
Jorgen Enoksen
2003 Allroad TQ
Old 05-05-2012, 05:48 AM   #4
Kneale Brownson
Jumper the connectors on the front pads with paperclips and see if the lights all go away. If not, then you probably have some other sensor issue.
Old 05-05-2012, 06:55 AM   #5
JustMtnB44
Search for brake light switch - I believe that is what causes the trifecta of warning lights to go on.
2004 allroad 4.2 - Ebony Pearl Effect FBP - H-sport sway bars - Phatbox MP3 player - stock 18" wheels with Continental DWS tires - stock 17" wheels with Yokohama Geolandar tires - custom tow hitch
JustMtnB44 is offline   Reply With Quote
Old 05-05-2012, 08:01 AM   #6
joenok
joenok's Avatar
Kneale, the new discs and pads are going on this week, guess iŽll wait and see.
JustMtnB44 - You might be on to something. Do you now where the switch is, located on the brake pedal?
Today, when i drove home from work, i started the engine, waited for 10 secs, and then pushed in the brake and set the car in R. No warnings at all today.
So this is some kind of sporadic issue.
Jorgen Enoksen
2003 Allroad TQ
Old 05-06-2012, 11:25 PM   #7
joenok
joenok's Avatar
yesterday, god the three warnings, found out i had no brake lights.
So I ordered a brake light switch.
Seems to be intermittent though, works like a charm today.
Jorgen Enoksen
2003 Allroad TQ
Old 05-07-2012, 09:53 AM   #8
fjasper
2002 Audi allroad
fjasper's Avatar
Quote:
Yup.
48 C170, 99 Miata, 03 Katana 600.
Never attribute to malice that which is adequately explained by stupidity.
fjasper is offline   Reply With Quote
Old 05-08-2012, 08:30 AM   #9
Ride2Live
I had the same thing happened and it turned out to be the brake pedal switch.
check this link....
http://allroadfaq.com/main/index.php...akes&Itemid=67
Ride2Live is offline   Reply With Quote
Old 05-09-2012, 06:19 AM   #10
thejulex
Scan the car....
I've seen all of these turn on for these reasons in the past:
ABS module issues
Steering angle sensor not aligned
MAF giving improper readings
Brake pedal switch problems
Short in tail lights electrical that was energizing brake light circuit
Without VCDS/VAG-COM scan it will be hard to pinpoint.
thejulex is offline   Reply With Quote
