Go Back   AudiWorld Forums » Audi Models » Audi A8 / S8 » A8 / S8 (D3 Platform) Discussion
Old 05-05-2012, 05:56 PM   #81
mishar
2005 Audi A8
mishar's Avatar
I agree about savings. Especially if you can't convert those few hours to that or more money, or even more if you enjoy and relax doing it.
No sophisticated electronics ab front. Just little harness to connect. Same as many. Only heavier parts.
mishar is offline   Reply With Quote
Old 06-04-2012, 05:15 AM   #82
BC996TT
Anyone have the actual OEM part numbers and sizes for the front and rear pads and rotors?
I've been to several sites all saying oem with different rotor diameters, etc.
BC996TT is offline   Reply With Quote
Old 06-04-2012, 05:16 AM   #83
BC996TT
Quote:
Originally Posted by mishar View Post
Instructions mentioned are about VCDS procedure.
So, a battery charger is necessary to release the Ebrake with Vagcom??
Old 06-04-2012, 08:56 AM   #84
MP4.2+6.0
Default Can sort out the W12's...
Some of the sites seem to throw in the W12/S8 fitments: those are 385mm front, 335mm rear. If you have a 4.2, clearly just skip past those sizes and fitments.
If a site is still confused, I move on. Not interested in hassles of returning parts if wrong, especially heavy ones like rotors.
Current #1: '06 D3 A8L W12 brilliant black w/ amaretto; 4 seat setup, CPO; modestly VAG COM lowered, H&R 20mm rear and 12mm front DRs with 275/35 on OEM polished + forged 20's; S8 sway bars (see: rear bar and gen'l D3 bar info and front bar); tweaked 385mm front factory brake mod and matching rear brake mod; matching C6 A6 back headrests (better rear view: headrest tweak); owner installed AMI retrofit with part number details here; uprated fogs; other VAG COM tweaking to suit.
Current #2: C5 '00 A6 4.2 ming blue w/ beige, new off showroom floor; Lemiwinks + VAG COM tweaks; smoked tails; RS 6 OEM 18's; RNS-D (CD) Navi
On order: 2013 Q5 2.0T hybrid; Scuba blue w/ chestnut sport interior; Euro delivery approx. 7/2013
Prior (each modded): '96 C4 A6 2.8Q, still w/ family; '85 C3 5000S 5 sp FWD; '73 C1 100LS
helpful cross reference to a C6 post with MMI and other TSB's that also cover D3 A8's.
MP4.2+6.0 is online now   Reply With Quote
Old 06-04-2012, 08:59 AM   #85
MP4.2+6.0
Default Procedure is fiddling, but no...
you don't need a car charger. At least I haven't. But if your laptop is old like my PC dinosaur that got replaced by a Mac but is still needed to run VAG COM S/W, you may need a charger for that! ... it takes a while.
Old 06-04-2012, 09:17 AM   #86
tx170754
AudiUSAParts.com-call them they will take your VIN and give you the corect PN/s for both front rear brakes/rotors.
tx170754 is offline   Reply With Quote
Old 06-24-2012, 11:06 AM   #87
BC996TT
Do I have to run the Vag com twice when doing the left and rear pads/rotors?
I ran it once and replaced the drivers side rotors and pads no problem. Went to the pass side and took apart the calipers, but can not get the rotor off at all. Im not sure if it's rusted on or what? I've used WD40 and a soft mallet hammer to see if I could break it loose but this thing isnt budging at all. The drivers side was simple and came right off with no force at all.
Do I need to rerun the Vag setting to release parking brake again for the pass side rear?
Old 06-24-2012, 11:20 AM   #88
Mister Bally
I have had to use a torch to heat the rotor where it contacts the hub, After a minute, Beat the rotor off with a 10# sledge hammer. Popped it right off.
Mister Bally is offline   Reply With Quote
Old 06-24-2012, 11:29 AM   #89
subit0
2007 Audi A8L
My Garage
Default Dinosaur PCs
Quote:
I'm using a 12 year old Thinkpad with a battery that doesn't really hold a charge, but I have an outlet close to the driver's door, so at least it works to run VAG-COM. Not likely to see a Mac version of the software anytime soon, so perhaps I can jump to a tablet version (when it comes out and if it has full functionality).
subit0 is offline   Reply With Quote
Old 06-25-2012, 04:49 AM   #90
BC996TT
Yes, I literally had to beat the rotor silly and it finally broke free. The rears were a piece of cake. The fronts a PITA b/c of the extra bolts that needed to be removed and replacing the caliper clip.
I ran through the vagcom settings per instructions and I still have the annoying brake pad warning icon. I've hooked up the new sensors and pressed the brake pedal a few times, even drove around the block and it's still there.
Is there something else I need to do to clear the code? I tried clearing codes via vagcom but it's still there.
a8l, brake, brakes, break, buy, c5, front, in, irotor, pads, replace, rotor, rotors, rs6, s8
