| Welcome to AudiWorld! | ||
| TT (Mk1) Discussion Discussion forum for the Mk1 Audi TT Coupe & Roadster produced from 2000-2006 |
#1 | ||
Did you have any luck with this problem, I'm getting a " unable to connect " when I attach a code reader to the plug . it looks like it might be the same problem. Also, does the code reader plug have a fuse in line with it ? I asked a dealer that question and they said that there was no fuse.
#3 | |
Quote:
#4 | |
2001 Audi TTJoin Date: May 2002
Quote:
Make sure you don't have an aftermarket radio, many of the harnesses are wired incorrectly and connect 12 volt to the K-line which messes things up. Check Ross-tech's site (aftermarket radio problem) for how to fix it. The other two modules that will block a connection are the cluster and the ABS controller.
2001 180 TTQ coupe 1976 Triumph Spitfire 2008 A4Q 2.0T (sold) 2003 A4Q 1.8T (sold) 1996 A4Q (sold) |
Mine has the factory radio .
Unplug ABS and cluster, try it again.
| 1998, a4, a5, a6, audi, board, diagnostic, diagnostics, fuse, ii, obd, obd2, port, rs, system, tt |
