| Welcome to AudiWorld! | ||
| A6 / S6 (C5 Platform) Discussion Discussion forum for the C5 Audi A6 and S6 produced from 1998-2004 |
#1 | ||
2007 Q7 3.6 Premium 2003 A6 3.0 1980 MGB Limited 1959 Austin Healey 100-6 (under restoration) 2005 Ford Escape - Daughters |
don't add any crap to the coolant !
2001 A6 2.7t 6-speed; ECU & BiPipe by APR |
2002 Audi S6Join Date: Oct 2002
Chances are you'll have to rip it apart again and redo the thermostat/gasket. Sucks to be you.
You may be able to see it--just below the t-stat housing on the front of the engine. There's s little recess where the coolant tends to dribble.
I managed to (be stupid and) crack the plastic t-stat housing while doing this. It was a very small crack leading away from one of the mounting bolts. I'm not sure if the 3.0's have the plastic housing or the metal one, but you might want to check if you think you may have stressed it. If I recall, it was possible to get the housing off without completely removing everything, but it was still pretty invasive. But with practice comes speed! |
those crappy plastic thermostat housings crumble apart and crack all the time. To save doing it again i would get the stat housing as well. And do not use any sealer or RTV on the o-ring when installing.
1992 Audi 100 CS Quattro 1990 Audi 200 Avant Turbo Quattro 1991 Audi 200 Turbo 1999 Audi A6 Avant |
I have a steal housing, all I did was replace the left bolt with one that has a head on it and crank it down, so far so good, those allen head crap you can;t get anything down there to tighten them. the right side I can get a allen socket on it and tighted that down. haven't had to fill my resivor yet. but I'll give it some more time, we'll see, may have gotten lucky...
So you didn't have to tear it down and reseal the thermostat housing? Just replace one bolt?
Yes that's right. You can take the thermostat housing off with two bolts after you take the plastic covers off. This is the 3.0 engine. So far so good. The Allen head bolts are all rusted.
#9 | |
2002 Audi A6 Avant 3.0Join Date: Nov 2010
Quote:
| 100, 1991, 28, a6, audi, fsi, leak, leaking, replacement, thermostat |
