Old 04-25-2012, 06:47 AM   #1
clancy
Default a/c dead or aux fan dead?
My kid poked a small tree branch through the a/c radiator. It looks like it only separated the cooling vanes (?) on the a/c radiator. Meaning it does not look like it broke the actual cooling tubes. There is no oil staining on the exterior of the radiator as I thought you got from the lubricant in the coolant if it leaked out from break in the radiator.
Anyway, the electric fan does not come on when the a/c is on and the air does not get cool at all. It worked fine prior to the tree branch incident. It is my understanding that if the coolant is below an acceptable level the air compressor does not come on and the electric fan does not activate. Is this correct?
Also, the tree branch incident did not penetrate to the coolant radiator, but that radiator had to be replaced as it sprung a leak where the plastic tank on the end started leaking. So the car must have taken a significant bump. He spun out on the road avoiding a deer and ran off the road. Anyway, I replaced the coolant radiator. But did not properly attach the upper radiator rose. It blew off later and the car lost the coolant and overheated for a couple of minutes. During this time the aux fan never came on. So maybe the a/c is not coming on because the aux fan is not working?
Is there a way to verify this with a VAG COM?
clancy is offline   Reply With Quote
Old 04-25-2012, 12:10 PM   #2
turbo510
2007 Volkswagen Touareg
My Garage
VAG-COM will run the electric fan as one of the output tests (I think when checking the HVAC module). This fan should run during an over-temp situation, so the status of freon pressure shouldn't matter. Does the AC compressor clutch click on when you select AC? One way to see if the freon leaked out or not is to remove one of the caps over the test connectors, which have Schraeder valves, and tap the valve to see if you get a puff of gas. That won't tell you if there is enough to cool, but will tell you if it all leaked out.
1996 Audi A4 2.8
1972 Datsun 510
turbo510 is offline   Reply With Quote
Old 04-28-2012, 12:06 PM   #3
clancy
I am embarrassed. I ran the VAG-COM scan and got the 00792 A/C pressure switch F129 open or short to ground. Removed the bumper and sure enough the switch was unplugged. My bad. Forgot to plug it back in after replacing the coolant radiator. Sure is simple when you remember to do the basics, like using the tools at hand.
Old 04-29-2012, 12:40 PM   #4
turbo510
My Garage
Aways nice when its that easy!
1996 Audi A4 2.8
1972 Datsun 510
2004, 28, a4, ac, audi, aux, auxiliary, auxillary, b5, coming, fan, fuse, test, testing, vag
