| Welcome to AudiWorld! | ||
#1 | ||
1997 Audi S6Join Date: Nov 2006
Thank you for the write up, on the money for sure. Being the cheap guy that I am and not wanting to shy away from a challenge I did the same thing for my 96, that was over three years ago and still functions perfectly. I was able to pick up a seal at a local jobber which was a little smaller than original (not quite as tall). They cost me $3.00 each however the cost of the calipers have gone down quite a bit and I'd certainly weigh that against the fuss of repair. I was thinking of doing a write up and was too far into it when it crossed my mind, so I'm really glad you did it. For sure this is not for the faint of heart, make sure you've got the gear if you tackle this. Kudos to you P.D.Q.
![]() Join Date: Mar 2003
Nice write up. Is that oddball p-brake mechanism unique to the C4 S-car series? I dont recall seeing it on my regular C4. Admit i didnt yet rebuild the (rear) calipers. Fronts i did. Fairly simple.
G
glenahan@vee-eff-email*dot*net |
A6 rears are smaller in piston diameter than the S6, it's a little easier to work on the S calipers, other than that they are the same
2002 Audi S6Join Date: Oct 2002
Really an excellent writeup! I will check the handbrake seal on my rear A6 caliper that I'm currently down for replacing the dust boot that tore...don't ask!
Two suggestions: 1. A drill press can be used to unload the spring the remove the handbrake mechanism from the caliper. That little spring looks pretty strong. Gear puller setup looks cool! 2. Per Audi, the piston seal is supposed to be soaked in brake fluid or a special lubricant for 30 minutes that comes with the OEM seal kit. That being said, I've used brake fluid. Works fine. The seal lives in brake fluid!! My audi technician friend says the dust boot has to be put on with the piston out; my plan was to simply replace the dust boot but now that I see the handbrake mechanism seal can fail I'll have to look at it more closely! |
you're the man. I just did this job and used your guide as a reference. I will be posting some pictures of my alternate "tools" and approaches, it was difficult to get it done without the right tools but I made it work. I'll post pictures and explanations soon. Right now I am enjoying a few celebratory Rolling Rocks
Thanks again to the OP for a layout of what the setup inside is like!
anyone have any idea where to get a rebuild kit for the rear caliper that is in North America ? usually the rebuilt kits just come with a seal and dust boot.. you need all the stuff tho
| a4, audi, brake, caliper, calipers, cold, kit, rear, rebuild, rewind, s4, s6rearcaliper, sticking, tt, weather |
