| Welcome to AudiWorld! | ||
#1 | ||
Well did the power steering work. The whining could be the powersteering pump screaming from no fluid. Or its bad. Or The alternators bearings shot, a idler pully or tensioner pully is bad, timing belt stuff. All could be making the noise. See it needs a brake light switch, easy. The central lock stuff, ignore it, i see stuff in like every single audi/vw i scan at my job.
other thing to look at. Those engines are known for the pickup tube for the oil pump clogging and starving the engine of oil and causing the dreaded oil pressure light. Most of the time, they wont cause the oil light untill they have been at highway speeds for 10+ miles. And if they keep being drivin its worse and worse till the engines destroyed and the oil light is always on. So if you just idled it for a while in the parking lot or just went around the block, you wont know. As far as price. I would say like 1800$ - 2000$ would be alot more fair with issues, How are the tires? Glass? |
The tires on both cars look decent for at least the time being. The glass was all in good shape except for the side mirrors. They looked to be wearing away around the edges and working their way towards the middle of the mirror. Is this a common problem? They both have this issue. I go test drive both this weekend so I'll know alittle more about drivability and such then. Any other things I should look out for?
