| Welcome to AudiWorld! | ||
| Brakes Discussion Discussion forum regarding brake tuning, upgrades and questions |
#1 | ||
Current - 2012 A7 3.0T CdnPP(US Prestige), Glacier White, S-Line, Black interior w/Brushed Alum trims, 20" Pirelli P Zero, Ventilated Seats, Driver Assist Package (ACC & Side Assist), BOSE, Full LED Headlights. Traded -2010 Q5 3.2 Premium+ - Stratos Blue / NAV / B&O /All-seasons Michelins on 19" Wheels Lease returned 2007 BMW 335i Coupe Lease returned 2002 Volvo S40 Wagon Sold - 1999 Merc E320 4-Matic Sold - 1991 Volvo 744 Turbo |
![]() Join Date: Mar 2003
its not very precise. The sensor is nothing more than a wire embedded in the pad. when it makes contact with the rotor, or cuts through, the light goes on.
Typically you have 2+mm of pad material left, which is a lot, really. of course, switchbacks through the Rockies might be challenging. Why not take the wheel off and look for yourself? bear in mind a new pad is about ~10mm pad material,plus backing plat of around 3-4mm. Did that 5-7 include the backing plate? Its only a 300% difference :-) G
glenahan@vee-eff-email*dot*net |
The answer of your first question is that the car run about only 900 miles maximum, the second ting there is only false lighting when you got your sensor out of order, to check whether the light is ok or not just measure the thickness of the pad that is 5 mm maximum. So I suggest you to do not take the risk as these are your business trip...
Where do you get your numbers from? 900 miles?
what assumption are you making about pad vs backing plate? I don't see how you can assert what you are asserting. G
Thanks for your inputs guys.
I did get the front brake pads looked at before I left for the trip. Was told by a couple of independent mechanics that it should be safe to go. On some of those long mountain downhill passes I used a combination of engine and brakes to slow down when I need to. Just got back - all good. The Q5 (3.2li) drives like a dream! Lots of power, very stable, and quiet at speeds up to 150 kph to momentarily 180 kph. Cruising at 120 - 130kph returned a manually calculated consumption of 30 to 32 mpg(UK). My Centric Posi-Quiet Pads and Power-Slot Rotors had also just arrived. Going to get all four corners fixed tomorrow. Should eliminate at least 80% to 90% of brake dust problem, as experienced by fellow forum members using the same setups.
Current - 2012 A7 3.0T CdnPP(US Prestige), Glacier White, S-Line, Black interior w/Brushed Alum trims, 20" Pirelli P Zero, Ventilated Seats, Driver Assist Package (ACC & Side Assist), BOSE, Full LED Headlights. Traded -2010 Q5 3.2 Premium+ - Stratos Blue / NAV / B&O /All-seasons Michelins on 19" Wheels Lease returned 2007 BMW 335i Coupe Lease returned 2002 Volvo S40 Wagon Sold - 1999 Merc E320 4-Matic Sold - 1991 Volvo 744 Turbo Last edited by ben_aip; 10-23-2011 at 11:49 PM. |
| a4, a5, allroad, audi, brake, break, drive, indicator, light, mtn, pad, pads, picture, rotor, safe, warning, worn |
