Oil pressure sending unit
Hello,
I have a '03 A6 Quattro with the 3.0 engine, auto tranny, 118k miles. Recently it has been intermittently displaying a low oil pressure warning on the dash. I am going to start with replacing the oil pressure sending unit, I ordered one and it should be here in a few days. Where exactly is this sending unit located? Is it easy to get to and change?
Thank you for your help
the oil pressure switch is located above the oil cooler where the oil filter goes...its a little trickey to get to...there is a tsb on the oil pressure lights coming on on those engines, more than likely you have a massive oil leak at your adjusters or the oil check valves are bad in your block
link to tech bulletin
Margus
12v V6 Discussion
02-26-2009 09:49 PM
Which wire coming off of the oil sending unit on the oil pan do I tap into for a oil pressure guage?
SNogaro4
05-14-2006 07:24 PM
audirunner
03-28-2004 08:56 AM
