Normal Oil Pressure?
Old 10-31-2009, 03:12 PM
rwester19's Avatar
Default Normal Oil Pressure?
What is the normal oil pressure for a b5 at idle, at normal operating temp?
Old 10-31-2009, 03:22 PM
donromani's Avatar
The OEM oil pressure sender for the b5s4 is rated between 1.2 and 1.6 bar. I suspect that the normal operating pressure is somewhere in that range but I don't know the exact number.
Do you have an oil pressure gauge installed? What reading are you getting?
Old 10-31-2009, 05:46 PM
rwester19's Avatar
nope... haha i wish i had a gauge mounted in the car. A buddy of mines got the tool for testing pressure. So im thinking about borrowing that from him... ill report any findings if i end up going threw with it.
Old 10-31-2009, 07:19 PM
donromani's Avatar
Are you worried you might have a leak, or what's your reason for testing the oil pressure?
Old 11-01-2009, 11:01 AM
rwester19's Avatar
Yeah im worried that ive got a leak somewhere. Its hard for me to tell tho because my driveway has oil stains all over it from when an oil cooler line went on my truck. I want to test it... drive it for a week... .then test it again to see if there is a drop. I havnt owned the car for too long and i cant get a good reading from to dipstick. Valve cover gasket looks good, no oil on the plugs. i can see any oil residue anywhere else. I got to do a timing belt soon.. i dont want to get it apart to find that i need a cam seal or something. Where do these things leak
Old 11-01-2009, 02:22 PM
donromani's Avatar
They actually are not that prone to leaking oil but when they do it is the typical culprits: seals, gaskets and so on. The oil cooler and oil pan can leak small amounts as well.
If you have existing oil spots on the floor then try putting down a big piece of cardboard and parking only the Audi on it. If you have stains on the cardboard then you'll know.
Tourette(AFC2.812v)
12v V6 Discussion
03-17-2005 08:24 AM
HACK THS
03-07-2005 04:47 PM
thoraudi
Audi 100 / A6 (C4 Platform)
07-06-2002 09:13 AM
Deutschdan
10-12-2001 09:26 AM
Aleki
08-13-2001 04:04 PM
Quick Reply: Normal Oil Pressure?
