Go Back   AudiWorld Forums » Technical Discussion » Motors » 30v V6 Discussion
Old 09-15-2007, 01:10 PM   #1
Boosted_4cyl
Default 98' 2.8 30v Headgaskets (rumor has it they dont fail)
How common is it for them to fail? I have 135k/mi always run 90+ octane and enjoy a spirited drive on occasion. Now i have an overheating problem, and I am praying its not the headgaskets, I just really dont want to do them, I wast getting ready to list the car for sale in order to buy a turbo a4 with less miles.
Boosted_4cyl is offline   Reply With Quote
Old 09-15-2007, 03:37 PM   #2
4Rings::G2 boosted::
Banned
Default it's not the headgaskets. Probably your t-stat is going bad.
4Rings::G2 boosted:: is offline   Reply With Quote
Old 09-15-2007, 04:46 PM   #3
Boosted_4cyl
Default Re: it's not the headgaskets. Probably your t-stat is going bad.
It starts to overheat and boil over in the tank. I shut it down and crack open the air vent on the coolant tube under the front of the intake and nothing but steam comes out. Upper rad hose gets warm but not too hot and the intake itself stays cool. I dont think a cooling flush has ever been done on the car. Will audi antifreeze boil after 10 years of use? or would a thermostat be more likely. Im just hoping its not not the headgaskets. I always run 91+ octane
also when its hot and i squeeze the rad hoses they are not super tight like they would be if they were crammed with pressure from leaking headgaskets.
no leaks, runs great.
Thanks a lot for your help
Old 09-15-2007, 08:57 PM   #4
Tr00p3r
I got 327,000 on original gaskets
Tr00p3r is offline   Reply With Quote
Old 09-16-2007, 09:59 AM   #5
4Driver4
Tech Guru
4Driver4's Avatar
Default Keep driving it and it will be the headgaskets...and the heads and the block. Replace the t-stat.
4Driver4
"Never give up the throttle until the bitter end." -RC
2005 A6 Sedan Q 3.2 (wife's whip)
2000 A4 Avant Q 2.8 (daily driver)
2003 Mini Cooper S (Fun!)
1995 Mazda Miata: the anti-Audi
1999 Mazda Miata SSB: track beotch
2003 GMC Yukon Denali XL: the anti-earth
2004 Dodge Dakota: hey, at least it's stick and 4x4
4Driver4 is offline   Reply With Quote
Old 09-16-2007, 05:01 PM   #6
77'911
Default a comment....
Its probably coming time for a new rad, and a few other coolant system components(sensors, fan, t-stat). I found ours was leaking and loosing some of its cooling efficiency around 58k(changed it out). Head gasket issues are somewhat rare on these motors but anything is possible with Audi. If you let the car over heat more then once, you might be replacing headgaskets and installing remaned head. These engines do not like to be over heated at all. It also makes a difference if the car had regular coolant changes.
77'911 is offline   Reply With Quote
Old 09-17-2007, 04:38 PM   #7
S4_Cinci (I S'edTFA)
S4_Cinci (I S'edTFA)'s Avatar
Default Your radiator likely has blocked passages, since coolant has never been changed.
2002 S4 Laser/Silver 6-speed
Cold, Premium, Bose, Changer
<Brian May guitar riff>..."I'm in love with my car, got a feel for my automobile"...I OWN an S4, I DROVE many a service loaner from Enterprise! $19k+ worth of warranty repairs. Tally ended on 8-23-05! She's now free of the man; DIY all the way! Now spending AoA retroactive cash back bonus for crappy dealer service! Thanks for the check, AoA!
Please help to fight window-licking!
(I hear they have a cure over on Audizine...)
S4_Cinci (I S'edTFA) is offline   Reply With Quote
Old 09-17-2007, 07:03 PM   #8
Boosted_4cyl
Default Pulled the thermostat out and I cant even pry it open with a screwdriver. Thanks a lot everybody!
Old 09-18-2007, 07:25 AM   #9
Default ...unless it is something really simple like a bad t-stat... ;^P
Old 09-23-2007, 09:15 PM   #10
mezonesxbox
mezonesxbox's Avatar
Default maybe your waterpump is dead.. like shattered impeller
mezonesxbox is offline   Reply With Quote
