Brakes Discussion Discussion forum regarding brake tuning, upgrades and questions
When would one need to rebuild a caliper?
Old 01-19-2006, 08:06 AM
akula-ssh's Avatar
Default When would one need to rebuild a caliper?
After seeing these pictures, someone told me the pistons look like they are worn and need replacing. What's your opinion?
<img src="http://pictureposter.audiworld.com/70933/img_0235.jpg">
<img src="http://pictureposter.audiworld.com/70933/img_0237.jpg">
I thought they look just fine myself, but since this somebody supposedly really knows about brakes, I'm now worried...
Old 01-19-2006, 12:47 PM
ryans4's Avatar
seals and bleed screws are pretty cheap, might as well replace while the calipers are not installed
Old 01-19-2006, 01:42 PM
akula-ssh's Avatar
I was told I need new PISTONS though, which is why I'm so worried. Do they look off to you?
Old 01-19-2006, 03:24 PM
ryans4's Avatar
Default tough to tell if it's rust or dirt or whatever...
...but when they are out for the seal replacement, you can clean them up good and give them a thorough inspection. The critical part of the piston is not the part that touches the pad, it's the part inside the seal. if that has wear or the sides have wear, then I'd consider new pistons. If not, put them back in.
Old 01-19-2006, 07:19 PM
akula-ssh's Avatar
Thanks for the response!
Old 01-20-2006, 08:30 AM
CP
CP's Avatar
Default Any tips for dual piston calipers?
I've got to replace my ripped seals this spring. Hopefully they don't rust up before then. I've heard that it's pretty hard to get both pistons back in, because as you push one in, the other wants to come out. Or is this not an issue when the brake line isn't hooked up?
Old 01-20-2006, 11:21 AM
ryans4's Avatar
Put a block of wood or something in there to keep the pistons from moving...
Old 03-01-2006, 09:28 PM
Just Paul's Avatar
it helps to have the bleeder open too.
burnte
11
12-01-2008 04:34 AM
Slush Puppie
08-10-2006 09:39 AM
2000SForce
02-27-2006 02:23 PM
urgti
08-01-2003 09:55 AM
Quick Reply: When would one need to rebuild a caliper?
