Go Back   AudiWorld Forums » Audi Models » Audi S4 / RS4 » S4 (B6 & B7 Platforms) Discussion
Old 12-27-2006, 08:25 PM   #1
Eddie Man
Eddie Man's Avatar
Default Finally got the chance to Clear Corner the "S"...
After researching most of the archives on AW, AZ & VWV, I was finally ready to bake...
Completion Time for me on this mod = 1 hour.
Difficulty (1easy-10very difficult) = 4
Here's some highlights that I've discovered while doing my ClearCornerMod...
1. First of all, I decided not to actually pull the entire bumper this time around. I pulled the bumper several times now and after being very proficient with it, I thought that removing the wheels & removing the belly pan was not completely neccessary this time.
Do this mod, only one side at a time. Turn wheels all the way to the left to clear fender work for the passenger side. To the right for the driver side.
This really sped up the whole process.
[img]http://render2.snapfish.com/render2/is=Yup6aQQ%7C%3Dup6%3DzqH%3AxxqUD7qRUrKxzX7BHpUUKx gXPJP%3F87KR6xqpxQQQnx0olxooexv8uOc5xQQQ0PQPoaQlQe qpfVtB%3F*KUp7BHSHqqy7XH6gXPJP%7CRup6lQQ%7C/of=50,590,442[/img]
[img]http://render2.snapfish.com/render2/is=Yup6aQQ%7C%3Dup6%3DzqH%3AxxqUD7qRUrKxzX7BHpUUKx gXPJQ%3F87KR6xqpxQQQnx0olxooexv8uOc5xQQQ0PQPoaQlQJ qpfVtB%3F*KUp7BHSHqqy7XH6gXPJQ%7CRup6lQQ%7C/of=50,590,442[/img]
2. Remove assembly (5) clips & rubber trim.
[img]http://render2.snapfish.com/render2/is=Yup6aQQ%7C%3Dup6%3DzqH%3AxxqUD7qRUrKxzX7BHpUUKx gXPJP%3F87KR6xqpxQQQnx0olxooexv8uOc5xQQQ0PQPoaQlPQ qpfVtB%3F*KUp7BHSHqqy7XH6gXPJP%7CRup6lQQ%7C/of=50,590,442[/img]
3. Bake in Oven @ 150degF for 5 minutes. (250 has been used, however 150 is adequete)
I know, I need to run the SelfClean Function on teh Oven.
[img]http://render2.snapfish.com/render2/is=Yup6aQQ%7C%3Dup6%3DzqH%3AxxqUD7qRUrKxzX7BHpUUKx gXP0a%3F87KR6xqpxQQQnx0olxooexv8uOc5xQQQ0PQPoaQlPJ qpfVtB%3F*KUp7BHSHqqy7XH6gXP0a%7CRup6lQQ%7C/of=50,590,442[/img]
4. Pry apart face lense from assembly.
Use stubby screwdriver at the seams and seam lips.
[img]http://render2.snapfish.com/render2/is=Yup6aQQ%7C%3Dup6%3DzqH%3AxxqUD7qRUrKxzX7BHpUUKx gXP0Q%3F87KR6xqpxQQQnx0olxooexv8uOc5xQQQ0PQPoaQlPn qpfVtB%3F*KUp7BHSHqqy7XH6gXP0Q%7CRup6lQQ%7C/of=50,590,442[/img]
5. Here's some tools I thought I needed.
Only needed screwdriver (with sharp edges) and mini sledge or hammer.
[img]http://render2.snapfish.com/render2/is=Yup6aQQ%7C%3Dup6%3DzqH%3AxxqUD7qRUrKxzX7BHpUUKx gXP0o%3F87KR6xqpxQQQnx0olxooexv8uOc5xQQQ0PQPoaQloo qpfVtB%3F*KUp7BHSHqqy7XH6gXP0o%7CRup6lQQ%7C/of=50,590,442[/img]
6. Now for the best TIP...
Removing the amber. For me, smacking the amber out using brute force is not good in the fact that if not hit right, you'll screw things up or crack something you don't want to.
I used a screw driver w/sharp edges to smack the amber lense off...
I did it similar to how you would smack a cap off of a bottle.
After inspection, this is the BEST method.
And it only took 2 strategic wacks.
7. Stock blinker vs. Silver Coated Amber Blinker
>>> Bulb Size = #1156
[img]http://render2.snapfish.com/render2/is=Yup6aQQ%7C%3Dup6%3DzqH%3AxxqUD7qRUrKxzX7BHpUUKx gXPJa%3F87KR6xqpxQQQnx0olxooexv8uOc5xQQQ0PQPoaQl0Q qpfVtB%3F*KUp7BHSHqqy7XH6gXPJa%7CRup6lQQ%7C/of=50,590,442[/img]
8. Use channel locks to help bring the face lense back together with the assembly, then add the (5) clips as you work around the perimeter of the lenses.
Now back in the over for rebaking, reseting/resealing of the silicone glue. 5 minutes, same temperature.
NOTE & OBSERVATION:
There is plenty of gooie silcone glue that the OEM manufacturer has injected into the lense/assembly channel. Now time will tell, but after my inspection, there appears to be adequete glue for resealing. And the silcone stays pretty pliable after heating. Not like some other household glues out there that lose their usefullness after setting.
So, YES as simple as it is; Mushing back together is what you do, paying close attention that it is NOT sloppy. Fortunately, the glue is very elastic in that it actually springs back into place. IMO, if the oven was any hotter, the glue would of been A LOT messier and less workable.
[img]http://render2.snapfish.com/render2/is=Yup6aQQ%7C%3Dup6%3DzqH%3AxxqUD7qRUrKxzX7BHpUUKx gXPJo%3F87KR6xqpxQQQnx0olxooexv8uOc5xQQQ0PQPoaQl0a qpfVtB%3F*KUp7BHSHqqy7XH6gXPJo%7CRup6lQQ%7C/of=50,590,442[/img]
9. Removed Ambers !!!
[img]http://render2.snapfish.com/render2/is=Yup6aQQ%7C%3Dup6%3DzqH%3AxxqUD7qRUrKxzX7BHpUUKx gXPon%3F87KR6xqpxQQQnx0olxooexv8uOc5xQQQ0PQPoaQlJQ qpfVtB%3F*KUp7BHSHqqy7XH6gXPon%7CRup6lQQ%7C/of=50,590,442[/img]
10. Done
[img]http://render2.snapfish.com/render2/is=Yup6aQQ%7C%3Dup6%3DzqH%3AxxqUD7qRUrKxzX7BHpUUKx gXPJl%3F87KR6xqpxQQQnx0olxooexv8uOc5xQQQ0PQPoaQlGJ qpfVtB%3F*KUp7BHSHqqy7XH6gXPJl%7CRup6lQQ%7C/of=50,590,442[/img]
[img]http://render2.snapfish.com/render2/is=Yup6aQQ%7C%3Dup6%3DzqH%3AxxqUD7qRUrKxzX7BHpUUKx gXP0G%3F87KR6xqpxQQQnx0olxooexv8uOc5xQQQ0PQPoaQllo qpfVtB%3F*KUp7BHSHqqy7XH6gXP0G%7CRup6lQQ%7C/of=50,590,442[/img]
Lastly, Once you do this mod, one really needs to VAG their lighting systems to be in "European" mode...
Meaning that the amber lights will ONLY be ON when blinkers are called for. That's perfect and exactly how B6 Ecodes work. Check it out for yourself and they look awesome at night too, because again NO ambers. Whoot !!!
[img]http://render2.snapfish.com/render2/is=Yup6aQQ%7C%3Dup6%3DzqH%3AxxqUD7qRUrKxzX7BHpUUKx gXPon%3F87KR6xqpxQQQnx0olxooexv8uOc5xQQQ0PQPoaQlll qpfVtB%3F*KUp7BHSHqqy7XH6gXPon%7CRup6lQQ%7C/of=50,590,442[/img]
Before & After
[img]http://render2.snapfish.com/render2/is=Yup6aQQ%7C%3Dup6%3DzqH%3AxxqUD7qRUrKxzX7BHpUUKx gXP0e%3F87KR6xqpxQQQnx0olxooexv8uOc5xQQQoaJoJn0QoG qpfVtB%3F*KUp7BHSHqqy7XH6gXP0e%7CRup6lQQ%7C/of=50,590,442[/img][img]http://render2.snapfish.com/render2/is=Yup6aQQ%7C%3Dup6%3DzqH%3AxxqUD7qRUrKxzX7BHpUUKx gXPJa%3F87KR6xqpxQQQnx0olxooexv8uOc5xQQQ0PQPoaQlGo qpfVtB%3F*KUp7BHSHqqy7XH6gXPJa%7CRup6lQQ%7C/of=50,590,442[/img]
I know there are alot of write ups out there, but I hope some of these additional tips & findings, helps others.
Enjoy
UPDATE:
One Month Later w/ car washes, snow storms, sleet & rain...
NO LEAKS. Whoot !!! (again)
2006 S4 Avant
dolphin gray | 6speed | alcantara | premium | cold | bose | sirius | navigation | bluetooth | parktronic | ebony | carbon fiber
GOT MODS? >>> http://www.audizine.com/forum/showth...60175-Got-Mods
Eddie Man is offline   Reply With Quote
Old 12-27-2006, 09:55 PM   #2
metalevon
Default yea that definitly looks better...unfortunatly i would definitly screw it up if i tried.
No Longer Patiently awaiting arrival of my 2009 S5
Suzuka Gray Pearl on Magma Red...
S4 + Girl photos...
http://forums.audiworld.com/s4b7/msgs/57820.phtml
AIM:LevonLikesMetal
My Artwork
metalevon is offline   Reply With Quote
Old 12-27-2006, 10:48 PM   #3
Tgr_Clw
AudiWorld Uber User
Default You're a brave man.
2003 Brilliant Black Audi A4 1.8T quattro
Sorry. Can't handle vB. I am now at:
q u a t t r o w o r l d . c o m
Tgr_Clw is offline   Reply With Quote
Old 12-27-2006, 11:41 PM   #4
S4Johnson
Default Eddie..U R the man!
Moro Blue/Silver Napa/6sp Manual/Premium pkg || APR Snub Mount || HOTCHKIS H-Sport F/R || Bilstein PSS9's || ECS X-Drilled/Slotted 2 Piece Rotors || Neuspeed SS || GIAC || K&N || Full Milltek Resonated || Independent Fog Mod || PIAA Xtreme 4150K Fogs || E-Codes || JE DESIGN Roof Spoiler || RS4 Pedals || V1 W/Remote-mute in Shift Boot || Vellano VSQ 19x8.5
S4Johnson is offline   Reply With Quote
Old 12-28-2006, 08:29 AM   #5
briancl
Default Looks nice!
I've done a similar bake mod to clear my STi lights. It's easier than it looks/sounds. Not a lot to go wrong if you follow the directions.
Current
2005 Subaru STi Black
2007 Audi S4 Avant Black
Past
2003 Subaru WRX Silver
briancl is offline   Reply With Quote
Old 12-28-2006, 08:34 AM   #6
gtikid98
Default looks great! so have you put any more thought on doing the rs4 foglight grille's?
i'd love to see a more effective way to do it
gtikid98 is offline   Reply With Quote
Old 12-28-2006, 08:40 AM   #7
ELEVENS
2007 Audi RS4
ELEVENS's Avatar
Default Gawd, those DOT/NHTSA orange corners just look HIDEOUS!
______________________________
2007 RS4 Daytona Gray Pearl Effect
Silver Nappa Leather / Carbon Fiber Trim
Audi (Euro spec) SuperSport Plus Suspension, GIAC software
No Sunroof, rear airbags, resonator, or carbon
winter: 225/45x18 Dunlop WinterSport 3D
2010 Q5 Deep Sea Blue Pearl Effect
Cinnamon Brown Leather / Brushed Aluminum Trim
S-Line w/ 20's, B&O, & hitch
winter: 235/55x19 Blizzak DM-V1 on TTRS reps
ELEVENS is offline   Reply With Quote
Old 12-29-2006, 06:45 AM   #8
Eddie Man
Eddie Man's Avatar
Default Ha...Thanks. Believe me, it looks scary but actually pretty easy.
2006 S4 Avant
Old 12-29-2006, 06:46 AM   #9
Eddie Man
Eddie Man's Avatar
Default Thanks...BTW, it's Yodaman.
2006 S4 Avant
Old 12-29-2006, 06:46 AM   #10
Eddie Man
Eddie Man's Avatar
Default Thanks.
2006 S4 Avant
audiworld, blue, clear, corner, effect, fender, front, gxp0o3f87kr6xqpxqqqnx0olxooexv8uoc5xqqq0pqpoaqloo, gxpjp3f87kr6xqpxqqqnx0olxooexv8uoc5xqqq0pqpoaqlqe, imghttprender2snapfishcomrender2isyup6aqq7c3dup63d zqh3axxqud7qrurkxzx7bhpuukx, moro, pearl, qpfvtb3fkup7bhshqqy7xh6gxp0o7crup6lqq7cof50590442i mg, qpfvtb3fkup7bhshqqy7xh6gxpjp7crup6lqq7cof50590442i mg, s4
