Go Back   AudiWorld Forums » Technical Discussion » Electronics » VAG-COM Discussion
Old 05-13-2003, 12:48 PM   #1
Andy@Ross-Tech
Audiworld Premium Sponsor
Default Shiftpoints Analysis
Here's the general idea - acceleration in a single gear corresponds closesly with the torque curve. Your acceleration (change in speed over change in time) is greatest at the torque peak, and tapers off after the torque peak.
Using VAG-COM, I logged a full throttle run in each gear on a straight, flat road. I used block 005. Change in speed over change in time is acceleration. 9.81 m/s^2 = 1 g. The optimal shiftpoints are where the curves cross.
So, for my specific setup (note, this varies by car, mods, etc.), the optimal acceleration is obtained by shifting at:
1>2 6700 rpm (34 mph)
2>3 6800 rpm (62 mph)
3>4 6200 rpm (86 mph)
In Excel, I created 6th order polynomial trendlines for each data series (sounds WAY more complicated than it really is). This basically smooths out the data to make it more readable.
Interesting note: You will always get your fastest acceleration by shifting AFTER the horsepower peak (unless you have a CVT, in which case you will have the fastest acceleration by keeping the engine AT the horsepower peak).
Andy
Andy@Ross-Tech is offline   Reply With Quote
Old 05-13-2003, 09:02 PM   #2
escargot
Default You crazy son of a beeotch...
That's the coolest thing I have ever seen!
-Mike.
escargot is offline   Reply With Quote
Old 05-15-2003, 06:21 AM   #3
Mark P
Default Yeah, I've done the same, yet I keep Accleration in MPH/s...instead of g....
It's nice to see your acceleration in "MPH per second", as more people can understand that significance... ie when you are accleration at greater than 10MPH per second.
Also, did the 6th order smooth it out too much? Did you compare where they crossed at say, 2nd order?
Mark P
Current:
'08 Audi A3 2.0T DSG, S-line - Ibis White - website - 25k miles
'04 Porsche 911 Turbo, Speed Yellow - website - 29k miles
'01.5 VW Golf 4dr 1.8T, Satin Silver, APR Stg3 - website - 203k miles
'09 VW Tiguan 2.0T, Candy White - Hers
Previous:
'02 Audi S4 Avant, Imola Yellow, APR Stg3 - website - 191k miles
'00 Audi A4 1.8T, Silver - Quattrobonium website
Mark P is offline   Reply With Quote
Old 05-15-2003, 07:05 AM   #4
Mark P
Default And here it is...
I was just interested in "highway" shifting at the time, so I had just logged 3rd-5th. This shows:
3rd -> 4th shift at 93mph/6500rpms (where yellow crosses pink)
4th -> 5th shift at 113mph/6200rpms (where pink crosses blue)
Mark P
Current:
Previous:
Old 05-15-2003, 10:52 AM   #5
Mark P
Default Just out of curiosity, I plotted with Acceleration in g's to compare....
Mark P
Current:
Previous:
Old 05-13-2007, 08:12 PM   #6
toywolf
Default Re: Shiftpoints Analysis
i just did this on my 01 jetta 1.8t.
because of warranty issues at the end of last summer, then needed some cash so i sold my exhaust sitting my my garage (eek) and took off my TIP, so i'm currently stock, but have the apr 93 chip.
i found my best shift points are almost the exact same:
1st>2nd 6900 (37mph)
2nd>3rd 7000 (64mph)
3rd>4th 6100 (84mph)
when i had my 3" DP w/ dump tube i ran a 13.7@103mph and was shifting at 7k for 1st>2nd and 2nd>3rd and 6800 for 3rd>4th (friends recomendation), also had my friend's drag slicks on. also dyno'd 213whp/247wtq.
this was very helpfull. going to do the butt dyno test after i get my parts back in to compare it to the dynojet. and hope for a slightly faster 1/4 mile with my 3rd>4th shift a bit earlier.
toywolf is offline   Reply With Quote
18t, 2001, 200k, 7000, a4, analysis, audi, mark, point, ps, shift, shifting, shiftpoints, vag, website
HTML code is Off
