Old 02-05-2005, 01:24 PM   #1
amiro
Account #: 10084
Default Tire Q's: Is it normal for fronts to wear faster than rears? Those with Falken ZE512's...
how long are they tires lasting for you, with average driving (once in a while aggressive)? I've done 15,000 miles on these and they look like they only got 5000 left to go.
Should the front and rear tires be lasting the same? Maybe it has to do with the tire pressure? I go 36 pounds all around. I have 205/55/16's.
amiro is offline   Reply With Quote
Old 02-05-2005, 01:39 PM   #2
ianbis
Account #: 22912
Default I'm on my 3rd set my OEM Goodyear's went 53K BFG's went 60K now running Yoko's all 4 wore evenly
ianbis is offline   Reply With Quote
Old 02-05-2005, 01:48 PM   #3
tquattro
Account #: 18089
Default normal. Most of the load is on the front wheels esp during deceleration.
tquattro is offline   Reply With Quote
Old 02-05-2005, 03:29 PM   #4
maggio
Account #: 38996
Default very normal. you should rotate F to R every oil change.
and I should practice what I preach :\
maggio is offline   Reply With Quote
Old 02-05-2005, 03:46 PM   #5
amiro
Account #: 10084
Default Thanks. How long should the tires last? 20000 miles seems low, even for high perf all seas tires.
Old 02-05-2005, 04:01 PM   #6
Ray993
Rest In Peace
Account #: 83975
Default 2000 to 40,000 - all depends on the tire and the nut behind the wheel
20K to 30K is fine.
Ray993 is offline   Reply With Quote
Old 02-05-2005, 07:19 PM   #7
val1s
Account #: 49152
Default understeer should account for some of the front tire wear also..
val1s is offline   Reply With Quote
Old 02-06-2005, 06:06 PM   #8
runawayroger
Account #: 35703
Default you might want to get the alignment checked
I burnt up a set of Toyos in ~12Kmiles because the rear alignment was out.
runawayroger is offline   Reply With Quote
Old 02-06-2005, 10:18 PM   #9
amiro
Account #: 10084
Default How can you tell. Would there be a sign of that on the tires?
i thought bad alignment results in uneven tire wear, like too much wear on the inside of the tire or something. mine didn't seem to have that problem.
Old 02-06-2005, 11:08 PM   #10
runawayroger
Account #: 35703
Default It can wear unevenly, but mine wore fairly evenly.....
it was like they were vertically aligned, but the toe wasn't set correctly or something. I don't remember right now, but I can tell you this: It's a lot cheaper to find out your alignment is/isn't ok by going to a shop rather than buying a new set of Toyo Proxes after burnign them up in 12K miiles.
