Account #: 55993
Cornering in the B6, even with the Sport PKG, is just lackluster. After reading countless posts about sway bars, I opted for the RS4 rear sway bar upgrade and I can not make this any more clear:
This mod completely changes how the car handles. If you're considering it, stop and buy it. Now. For ~$100, you can't lose. On my 25 mile drive to work every day, I have lots of options here in LA but take a route that includes some open freeway [yes, even in SoCal], a massive curved flyover but more importantly some fun tight turns. I've now been throwing my car into corners [when safe, of course] and it just hugs everything! Rant concluded, here's some pix. I know this is a walk in the park for most of you fellas but figured it might help someone like myself who's just starting out. First and foremost, thanks to all who've posted on this topic before and especially A4mods.com for the instructions. The suspension needs to be loaded to perform this install. So, I picked up a set of Rhino Ramps from K-Mart for $32. Good investment. ![]() Removal of the rear exhaust hangars comes first. Piece of cake. Four bolts on each side and the exhaust hangs low to allow for removal of the bar itself. ![]() Set up the jacks to hold up the exhaust. Wasn't sure if this was necessary, but didn't want to run the risk... and it helped keep it stationary while I worked. ![]() Getting the sport suspension toothpick bar off the rear end didn't take too long as most of the bolts were easily accessible. Make sure you have some extensions for your ratchet set or you'll find this much more difficult [I think mine are a 3" and 5"]. It's easy to see tell how much more sturdy the RS4 bar is when you have them side by side. Now more then ever, I'm pretty stunned Audi didn't make the RS4 bar OEM on our cars. ![]() The new bushings are a bit larger than the OEM Sport. This comes into play shortly. ![]() Um, yeah, they don't fit so well. I pushed down hard on this and it sunk down about 80% of the way but floated back up in a matter of seconds. ![]() Maneuvering the bar into place and attaching the inner bolts on the driver's side required little effort. Be sure to not torque the bolts all the way down as you'll need to have some play in the bar for the other side! ![]() After futilely attempting to get the other side attached for longer than I'd like to admit, I figured out a new technique. Get the top part loosely attached, then position yourself directly underneath the bushing and slowly but forcefully wedge the bushing up into the bracket. This worked far better than anything else I tired. ![]() Then, I grabbed a set of pliers to get the gap closed enough to ratchet it down. I used needle nose pliers on the bushing as well. Be careful no to damage the bushing in the process. ![]() From here, line up the outer bolts and get them started. I put Blue Loctite on them beforehand, and applied it to the other four inner bolts as well before torquing everything down. Again, this mod is really worth the effort and money. My car now corners like it should! EDIT Here are the part numbers as well: 8E0511327D: clips x 2 [formerly 8E0511327B] N 10528103: bolt x 2 (for sway bar ends) N 10127707: bolt x 4 (for clips)
------------------------------------------------------------------------------------------- The switch to vB = FAIL I am now at: q u a t t r o w o r l d . c o m Installs: Alpine Head Unit | Blackout Grills | RS4 Rear Sway Bar | Strat Short Shifter | Delsa Rear Spoiler | Retro Solutions HIDs | * Comments may be peppered with sarcasm which are only intended for good times, never maliciousness. Last edited by A4darkness; 10-28-2009 at 09:14 PM. |
Account #: 107183
did you end up with a bunch of sand in your eyes like I did when you tried to position the swaybar?
Account #: 108769
![]() '02 A4Q 1.8T Light Silver Metallic "Catalina" *18" Hartmann Concept Nuvo wheels*S4 grille*Vibrant 1304's*Icelink*In.Pro Mirror Covers*Delsa M3 style trunk spoiler*A4 All Weather Mats* (it's the little things that count!) Winter setup: 16" OEM five spokes with Firestone Winterforce rubber. AKA: snow tank! |
Account #: 33354
I am dying to do this mod but I will only do it if I get a suspension.
Having non sport and an RS4 rear sway bar is a little backwords IMO>
![]() 2k7 B7 2.0T qTip, BB w/Ebony, Convenience, Premium, Bluetooth, Heated Seats, Sports Suspension, 18" S-Line Rims, RS4 Rear Sway Bar, S4 Alum Mirrors & Door Blades, Kerscher CF Splitter, Votex 3pc Rear Lip Spoiler, Painted Rear Valence, 38% Titanium Tint, V1, Nuvi 660, DICE w/ iPod Touch, Audi Sport Rubber Mats, Audi Sport License Frame, Battery & RS4 Engine Covers |
Account #: 105649
Lol both times I did it I just let the exhaust system rest on my chest. Not fun.
The bushing problem is interesting as well. I know in the H-Sport kit they give you a washer (and different brackets) to account for the difference in the rubber bushing. I'm assuming the RS4 bushings are a bit squishier, correct? The H-sports are pretty firm, for reference
-Matt ![]() 2004 Audi A4 1.8t 6MT Quattro "Modding is like herpes; once you get the itch, it never leaves."- OpenSkye Dahlback | Milltek | AWE | Vogtland | H-Sport | Oettinger | BFGoodrich | Thule | OEM+ | Dents Wish List: Stasis Torsen Center Differential, S4 Recaros (Black leather), Affordable parking in Washington DC KMD Tuning Stock Dyno (w/ Milltek): 162.5 HP; 164.5 ft/lbs TQ Dahlback Stage 2 Dyno (w/ AWE FMIC, Milltek): 244.8 HP; 312.8 ft/lbs TQ 2002 Audi 1.8t K04'd Tiptronic Gone but not forgotten |
Account #: 14421
You'd still be advised to upgrade the sway from the non-sport, but good suspension will dial out a lot of the understeer anyways, without having to resort to a thick sway that reduces rear suspension independence.
RS4 sway is a cheap fix for understeer, but a good suspension is a better answer. I'm cheap so I did the RS4 sway on my sport suspension, and I'm happy with it, but since you're doing suspension anyways...
MikeD ![]() 2004 A4 1.8TQM Ultra - GIAC FXK04 DSMIC | Southbend OFE SS | APR Stealth | B6S4 brakes | Neuspeed SS | RS4 sway | APR snub | APR TIP(removed, in garbage) | podi |
AudiWorld Uber User
Account #: 88605
2003 Brilliant Black Audi A4 1.8T quattro Sorry. Can't handle vB. I am now at: q u a t t r o w o r l d . c o m |
Account #: 92671
...we disconnected it by disengaging the rubber hangers, as opposed to the mounting point attached to the undercarriage. Much, MUCH easier.
OLight, WashDC 2009 A4 2.0T Q-Tip * Premium (ha) * BT * Homelink * Symphony w/ SD card (non-compliant to 3-year-old SDHC standard) RIP 14 Jan 09 2002 A4 Avant 3.0 Quattro * Canvas Beige * Tiptronic * Nav * PIAA Plasma Ion Yellow Foglamps * Sport Rear Sway Bar (Thx, Jimax!) * B5 S4 HP2 Front Calipers (Thx, apk-S4!) * Carbotech Bobcats * 17" B7 A4 2.0T 7.5Jx17 ET45 16-Spoke Wheels * Aero Wiper Conversion
Account #: 55993
And I always wear the goggles.
------------------------------------------------------------------------------------------- The switch to vB = FAIL I am now at: q u a t t r o w o r l d . c o m Installs: Alpine Head Unit | Blackout Grills | RS4 Rear Sway Bar | Strat Short Shifter | Delsa Rear Spoiler | Retro Solutions HIDs | * Comments may be peppered with sarcasm which are only intended for good times, never maliciousness. |
#10 |
Account #: 55993
| 4darkness, a4, audi, b7, bar, bars, ends, forum, hs, install, problems, rear, replace, rs4, s4, sway |
