| New! Use your Facebook to securely log into this site, click logo to login |
Account #: 68929
This morning it was cold out. A little precip on the windshield. I hit the wipers and one moved while the other tried to. Now it is a permanent thing. Are these things keyed? I see the shaft turning for the wiper, so things are still working. Am I correct to assume there is a key or something along those lines that broke?
I am not a mechanic. Any opinion expressed by me on these forums should be taken as an opinion, and not as professional fact or advice. Any opinion I leave that is in turn taken as advice or direction, is used soley at the discretion of the reader. There are no warranties expressed or implied in any of my posts. |
Account #: 49170
the wiper arm grooves for the splines arent very strong. I found this out the hard way last winter when I got lazy and tried to brush the snow off my window by using the wipers.......BIG NO NO.
I wasnt about to spend $50 for a new wiper arm. so I took a chisel and tried to make the grooves come back to life, then i locktited the wiper back on. has'nt moved since. I wouldnt recommend this fix unless you are aware of the fact that the wiper arm may never come off again
Adam in Michigan -90 Audi V8 Quattro *V8 twin turbo* -90 Audi V8 Quattro -80 Scout II *complete fiberglass conversion* -72 Ford Maverick w/302 -72 Honda CB550 |
Account #: 68929
Hmm, at least the fault is on the wiper arm and not the shaft. Thanks for the quick fix, I may use it.
Account #: 49170
Account #: 60980
LocTite, use a torch (careful!) or use a small puller and it will snap! I use alot of Locktite on pump bearings and some seals. I think a red will be ok. Some are real strong and may be almost impossable to remove w/o heat.
Account #: 62578
My wife and I work at the same company .... so when we got out of
work I started the Audi and went outside to scrape the windows ... I had just got the brush in my hands when I could see she was turning on the wipers ..... NOOOOOOOOOoooooooooo . The wipers were glued to the window by the ice ..... I immediately pulled them of the frozen tundra and found that both of them had been F*&^%ed . It was a quiet drive home with the wife looking the other way , but I didn't jump all over her, because I knew I could play in the garage. ( not that I need her permission ) As I investigated the wiper arm I noticed the nuts were very loose ... ooops I must not of tighten them after I repainted them in the summer. lesson learned ::: always keep you mouth shut :-)
1997 Audi A8 4.2L 1993 Audi V8 4.2L (summer Car I ) 1974 Corvette Stingray ( summer car II ) 1987 Audi 5000 CD qt ( SOLD) |
Account #: 68929
Account #: 28630
The motor drive under the hood also has one similar tapered drive, that should give way before the motor gets damaged.
'90 200qa - sold '96 A4q 2.8l auto '96 BMW 740iL '97 FZJ80 Landcruiser '06 Specialized Epic Comp Disk - daily driver Holland, MI
Account #: 68929
I tightened it. I called the local Audi guy and he said tighten the nut. Trusting his infinite knowledge I heeded his words.
But of course, the alternator belt is now loose... always gotta be something.
