Go Back   AudiWorld Forums » Technical Discussion » Electronics » Audio, Video and Security Discussion
Old 06-11-2008, 09:44 AM   #1
swrt83
Account #: 147801
Default Bose Symphony intermittent sound??
Hey guys,
My B6 came with the bose symphony sound package and i've been noticing that when it's really hot outside (ie above 85-90) that the sound coming from the speakers is REALLY strange. It will be at a quiet volume like level 3, and then get really loud (sounds like a 5 or 6) and then goes up and down, in and out from low to high volume. At first i thought maybe it was a poor radio signal, but tried the CD player and discovered it was all audio. Oh and this is when I start the car and drive for maybe the first 15 mins or so, unless its very hot outside. Seems to correct itself when I turn up the volume past level 5/6. Loose connection? Amp going bad? Looking for ideas, since this really only happens when the weather is hot. Thanks in advance.
swrt83 is offline   Reply With Quote
Old 06-11-2008, 10:12 AM   #2
AudiA4B6US
Account #: 86480
Default Comon issue in 2004 B6 with Bose
The fix is to replace the Bose amp to get update firmware or apply the TSB to disable the AudioPilot.
2004 A4 3.0Q Tip Avant Ultra Sport, Moro Blue, Premium, Cold Weather, Bose, XM, OEM Bluetooth, Color DIS, RNS-E, Dice iPod with XM
AudiA4B6US is offline   Reply With Quote
Old 06-11-2008, 10:54 AM   #3
swrt83
Account #: 147801
Default AudioPilot?
Wow. Thanks for the quick response! Audiopilot meaning the auto-level adjustment (you go faster, it gets louder)? Is this something the dealer will cover since its a known TSB?
Old 06-13-2008, 05:57 AM   #4
AudiA4B6US
Account #: 86480
Default It's noise driven, not speed driven
Dealer may do the TSB but it's better to get the amp replaced to keep Bose working as it should.
HTML code is Off
