Go Back   AudiWorld Forums » Technical Discussion » Electronics » Audio, Video and Security Discussion
Old 01-24-2005, 11:11 PM   #1
jayel
Account #: 27352
Default i want to put dynamat or brown bread my interior...
how much sq ft do you think i'll need for a TT coupe?
jayel is offline   Reply With Quote
Old 01-25-2005, 02:15 PM   #2
jayel
Account #: 27352
Default specifically is 100sqft overkill?
100 sq ft is only 33lbs with the bquiet extreme
thinking of going this path.
I've stfa, and found that you can use less, if you use it in strategic locations. What would be typical of these strategic locations? Where it is just flat bare metal? or where who parts meet?
tia!
Old 01-25-2005, 06:00 PM   #3
Eddie3dfx
Account #: 80191
Default How much for a 99 a4?
I was thinking of doing at least 30-50 sq ft
Eddie3dfx is offline   Reply With Quote
Old 01-26-2005, 01:25 AM   #4
jayel
Account #: 27352
Default guess we are on our own on this one...
let me know how much you end up getting/needing..
Old 01-26-2005, 09:30 AM   #5
EuroDriver
Account #: 24943
Default I used 3 layers of Dynamat Extreme on the door pockets
On flimsy plastic parts its well worth while to put 3 layers on.
Stay away from the brown tile like stuff, use only the black chewing gum on aluminium
Have Fun
EuroDriver is offline   Reply With Quote
Old 01-26-2005, 12:06 PM   #6
Eddie3dfx
Account #: 80191
Default Any idea how much sq feet you used in all?
Old 01-26-2005, 12:07 PM   #7
Eddie3dfx
Account #: 80191
Default I think 100sq ft would be overkill in a tt, the car is light as is
you definately don't want to put to much weight on that car and slow it down.
I would just say do the doors and the rear deck.
If that doesn't reduce the noise, try the wheelwell and trunk.
Old 01-26-2005, 01:20 PM   #8
EuroDriver
Account #: 24943
Default About 36 sq ft for the front doors only
HTML code is Off
